Old 10-03-2019, 09:39 AM   #1
hdixon
wheel Stud
Can anyone help me out. I need to change my wheel studs for longer ones and I am not sure what is the correct size for my 1969 c10 step side I would like to get some that is 3" long any help would be great
Thanks,
hdixon is offline   Reply With Quote
Old 10-04-2019, 10:12 AM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: wheel Stud
https://www.jegs.com/i/Moser-Enginee...010-1/10002/-1
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 10-04-2019, 11:02 AM   #3
hdixon
Re: wheel Stud
thanks for the help
Old 10-04-2019, 01:49 PM   #4
Jason Banks
Jason Banks's Avatar
Re: wheel Stud
I don't think the factory size on 1969 6 lug is 1/2-20.... I think it is 7/16 but you can drill them out for the 1/2-20....
Jason Banks is offline   Reply With Quote
Old 10-04-2019, 02:18 PM   #5
hdixon
Re: wheel Stud
It is 5 lugs
Old 10-04-2019, 04:17 PM   #6
HO455
HO455's Avatar
Re: wheel Stud
I would remove one and take it with me to the parts store to be sure I got the correct ones. There are quite a few different spline configurations out there.
RIP Bob Parks.
Old 10-04-2019, 06:05 PM   #7
hdixon
Re: wheel Stud
I can do that thanks everyone
Old 10-04-2019, 06:15 PM   #8
AussieinNC
Moderator
AussieinNC's Avatar
Re: wheel Stud
If you need 7/16 x 20 here is the Jegs link
https://www.jegs.com/i/Moser-Enginee.../8050/10002/-1
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 11-04-2019, 07:55 PM   #9
mygmctruck1
Re: wheel Stud
Ok , hoping some one can help me .
I need longer studs , for new aluminum wheels.
My 68 K1500 , has. 7/16 x 20 studs . My question is how do I determine the spline diameter ? I think they at .560. But I am not sure and need this size to order proper studs .
mygmctruck1 is offline   Reply With Quote
Old 11-05-2019, 12:38 AM   #10
sprint_9
sprint_9's Avatar
Re: wheel Stud
Pound one out and measure with a dial caliper. Measure both the stock stud and the hole. There should be a slight difference between the two. There is an acceptable range of a difference between the stud and hole for the proper press fit.
I would measure the front and back to see if they are the same. My rear's were a smaller knurl than the front, but I had aftermarket front brake rotors.
If you can find half inch threaded studs with the right sized knurl for the hole you have then it would be a good upgrade.
https://tech.arp-bolts.com/wheel-stud-fit.php
Also, depending on what you have for wheel thickness and lug nuts, closed end lug nuts specifically. Dont be surprised if you have to cut the studs to a custom length.
sprint_9 is offline   Reply With Quote
Old 11-05-2019, 06:13 PM   #11
mygmctruck1
Re: wheel Stud
I called dorman direct , they had all the info I needed . Saves a lot of guessing. Got the part number for my front hub studs
Old 11-06-2019, 03:55 PM   #12
cebra
Re: wheel Stud
Can you share, need to replace the front studs on my 71 5-lug but do not know the knurl size. It is a driver so I can't knock them out and measure without replacements ready to go.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 11-06-2019, 04:14 PM   #13
mygmctruck1
Re: wheel Stud
Go on line , get the dorman web site , they have a contact # . Call and go to tech dept. they also have an online chart , if you can locate you vehicle on it .
