10-17-2019, 11:38 PM | #1 |
Seat Lowering
I know there is a company making lowering brackets for the 67+ trucks, but can't find any info on lowering the stock bench in my 65.
Anybody done this with a kit or otherwise? Thanks, Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
10-18-2019, 07:47 AM | #2 |
Re: Seat Lowering
The bracket from a 67 should work. I had a 70 seat in my 66 for a while when I rebuilt my seat. Biggest difference in the seats was the later seat did not fold forward.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-18-2019, 09:59 AM | #3 |
Re: Seat Lowering
I found a link to Full Custom Fabrication that sells new seat brackets that lower your seat about 2 inches. Direct bolt on that took less then 30 minutes.
https://squareup.com/store/full-custom-fabrication/ |
10-18-2019, 09:59 AM | #4 |
Re: Seat Lowering
Here you go. I have them and love them; I'm 6ft 2".
https://squareup.com/store/full-cust...rackets-tall-2 |
10-22-2019, 02:26 AM | #5 |
Re: Seat Lowering
Thanks to all for the info.
Tom
10-22-2019, 05:47 PM | #6 |
Chevy addict
Re: Seat Lowering
Why would anyone want to lower the seat ?
10-23-2019, 12:19 AM | #7 |
Re: Seat Lowering
Was just about to order a set when I noticed that the only way to adjust the seat appears to be with slots in the floor mounting bolts. Unfortunately my wife also drives the truck, so that would not work. Am I missing something, or is there another way to do this?
10-23-2019, 12:22 AM | #8 |
Re: Seat Lowering
10-23-2019, 03:02 AM | #9 |
Re: Seat Lowering
I'm only 5'10" and feel my line of sight through the windshield is too high, but at the same time I feel like I'm raising my knees to my chin to work the clutch and brakes.
To those that's done this, did it make the pedals any more difficult to operate? |
10-24-2019, 11:51 AM | #10 |
Chevy addict
Re: Seat Lowering
I am 6' 4" and all I did was install 1/2" spacers under the front seat mounts. It's more about position than leg room.
10-24-2019, 12:04 PM | #11 |
Re: Seat Lowering
10-24-2019, 12:40 PM | #12 |
Re: Seat Lowering
There are 3 different sets of brackets / sliders that are different heights spread over the 6 years of trucks 1967-1972. I suspect that the person who "drove like they were having a baby" had a taller set mixed with a seat that was originally with another shorter set of brackets . . .
If you do a search on the 67-72 pages there is a post with very clear photos and descriptions of the three different set sizes.
PayPal 1windyridgeboy@gmail.com |
10-24-2019, 05:59 PM | #13 |
Re: Seat Lowering
My new seat foam was about 1" taller than the old foam. I assumed it was because the old foam had collapsed. But my skinny legs still hit the bottom of the steering wheel and I felt too tall and I'm short in the upper body.
I wanted to keep the seat brackets factory so my plan was to use a long saw to cut a 1" section out of the middle of the foam and glue it together. That way I didn't have to duplicate the upper or lower shapes. I didn't do it as I sold the truck before I had a chance. |
10-25-2019, 10:04 PM | #14 |
Re: Seat Lowering
I was curious about this too for these c10's, I also have a '47 I had to do some seat foam work and seat bracket fabrication to get work, not comfortable but it works , at 6' 7" I struggle with these older trucks.
The issue I have is my knees above steering wheel and into the dash, I also have to duck to see out of windshield. I need to do something with this C10 Thank you for the replies |
10-28-2019, 04:46 PM | #15 | |
Re: Seat Lowering
10-28-2019, 06:49 PM | #16 |
Re: Seat Lowering
Cool! Let us know how it turns out!
