10-09-2019, 12:55 PM | #1 |
How are others finishing behind seats with no gas tank?
Planning ahead in my mind while my truck is away at paint. My tank is moved to the rear. I have buckets to install. I'm wondering how others have finished that area. I think this will help with noise suppression as well. I envision something that wraps around the corner area. Here's some progress pics they sent me.
10-09-2019, 03:46 PM | #2 |
It's Better With Nitro
Re: How are others finishing behind seats with no gas tank?
I just ran the sound deadening up the back of the cab and installed the Auto Custom Carpet kit to help with the sound/drone attenuation. If you're into a big sound system, it's a great opportunity to build a custom speaker enclosure.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
10-09-2019, 07:27 PM | #3 |
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-09-2019, 07:34 PM | #4 |
I kept it low buck but decent. First i put the sound deadener stick on stuff covering around 60%, then jute pad, the carpet runner from Home Depot. My bottle jack lives in the cab corner and they are covered by block off panels made of heavy carboard which I painted black and attached fiberglass ductwork insullation to the backsides with spray adhesive. I used the adhesive on the back wall to keep the jute and carpet up too. I wasn't sure how to work around the old flanges on the wall for the tank straps so i just cut a little flap in the carpet. The glue came loose there, but I don't care.
10-09-2019, 10:30 PM | #5 |
I also did the sound deadening up the back and then covered it with this felt that I pulled out of a 97 regular cab. I had to clean it up and drill a few holes for the Christmas tree fasteners. I’m pretty happy with it.
11-04-2019, 03:55 PM | #6 |
Did some scouting around the wreckers this morning and came home with this for $10. It's from a 2004 F150 reg cab. I plan to trim the top off a bit to bring it closer to the back and I'll trim the bottom to follow the contours. The back wall has a bracket for the gas tank straps and I'm thinking I can utilize those with some slip on C clips nuts. It'll get some black vinyl paint. (you'll have to stand on your head to look at the pic)
11-06-2019, 01:56 PM | #7 |
I built this out of fibreglass. Has storage with a cover that opens and speakers on the ends.
11-06-2019, 05:26 PM | #8 |
rustbucket,that storage box with speakers is awesome.the mans got talent!!
nice work.i've never worked with fiberglass. |
11-06-2019, 06:22 PM | #9 |
x2!
11-08-2019, 07:46 PM | #10 |
But Found Her 25yrs Later!
X3
Real Cool!
11-09-2019, 05:56 PM | #11 |
Bigmoe, what color is your cab, the paint color is smoking hot.
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange 1964 GMC 1000 series,custom, 305E, sm420 |
11-09-2019, 07:01 PM | #12 |
11-09-2019, 10:31 PM | #13 |
Senior Enthusiast
When I swapped in bucket seats, I built a full panel behind the seats out of 1/8" ABS plastic covered in diamond tufted marine vinyl. I subsequently redid the entire insides with full door panels and full size diamonds:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
11-09-2019, 10:53 PM | #14 |
11-11-2019, 10:42 PM | #15 |
Here's that 04 F150 back wall panel painted and installed. It's pretty sturdy and the two bolts into the existing brackets on the back wall hold it nicely. I have two L brackets in each lower corner as well. I've ordered some 1/8" ABS bendable sheet plastic to form into the corners.
Why is my pic upside down? |
11-13-2019, 10:49 AM | #16 |
Perhaps a better view......
11-30-2019, 11:41 AM | #17 |
I got the corners finished. I bought .093 12 x 24 sheets of plastic (Kydex V) off of Ebay. I made cardboard templates. The Kydex I was able to form in a curve using some heat from a heat gun. There was some color variation so I sprayed it with the same vinyl paint I used on the centre section. I have Honda Odyssey door seals that have the extra lip on the inside and was able to slip the plastic into that lip.
11-30-2019, 07:20 PM | #18 |
bigmoe,that looks great!nice job
was the 04 fi50 a regular cab or does it matter? |
11-30-2019, 11:07 PM | #19 |
