Old 10-09-2019, 12:55 PM   #1
bigmoe
bigmoe's Avatar
How are others finishing behind seats with no gas tank?
Planning ahead in my mind while my truck is away at paint. My tank is moved to the rear. I have buckets to install. I'm wondering how others have finished that area. I think this will help with noise suppression as well. I envision something that wraps around the corner area. Here's some progress pics they sent me.
bigmoe is offline   Reply With Quote
Old 10-09-2019, 03:46 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: How are others finishing behind seats with no gas tank?
I just ran the sound deadening up the back of the cab and installed the Auto Custom Carpet kit to help with the sound/drone attenuation. If you're into a big sound system, it's a great opportunity to build a custom speaker enclosure.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-09-2019, 07:27 PM   #3
Clyde65
Clyde65's Avatar
I put an ACC rear wall carpet
https://www.stockinteriors.com/AutoC...ilterYear=1965
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-09-2019, 07:34 PM   #4
AcampoDave
AcampoDave's Avatar
I kept it low buck but decent. First i put the sound deadener stick on stuff covering around 60%, then jute pad, the carpet runner from Home Depot. My bottle jack lives in the cab corner and they are covered by block off panels made of heavy carboard which I painted black and attached fiberglass ductwork insullation to the backsides with spray adhesive. I used the adhesive on the back wall to keep the jute and carpet up too. I wasn't sure how to work around the old flanges on the wall for the tank straps so i just cut a little flap in the carpet. The glue came loose there, but I don't care.
AcampoDave is offline   Reply With Quote
Old 10-09-2019, 10:30 PM   #5
Vinceg
Vinceg's Avatar
I also did the sound deadening up the back and then covered it with this felt that I pulled out of a 97 regular cab. I had to clean it up and drill a few holes for the Christmas tree fasteners. I’m pretty happy with it.
Vinceg is offline   Reply With Quote
Old 11-04-2019, 03:55 PM   #6
bigmoe
bigmoe's Avatar
Did some scouting around the wreckers this morning and came home with this for $10. It's from a 2004 F150 reg cab. I plan to trim the top off a bit to bring it closer to the back and I'll trim the bottom to follow the contours. The back wall has a bracket for the gas tank straps and I'm thinking I can utilize those with some slip on C clips nuts. It'll get some black vinyl paint. (you'll have to stand on your head to look at the pic)
Old 11-06-2019, 01:56 PM   #7
rustbucket66
I built this out of fibreglass. Has storage with a cover that opens and speakers on the ends.
rustbucket66 is offline   Reply With Quote
Old 11-06-2019, 05:26 PM   #8
oldtrux
oldtrux's Avatar
rustbucket,that storage box with speakers is awesome.the mans got talent!!
nice work.i've never worked with fiberglass.
oldtrux is offline   Reply With Quote
Old 11-06-2019, 06:22 PM   #9
SCOTI
SCOTI's Avatar
x2!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-08-2019, 07:46 PM   #10
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
X3
Real Cool!
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is online now   Reply With Quote
Old 11-09-2019, 05:56 PM   #11
sstock
sstock's Avatar
Bigmoe, what color is your cab, the paint color is smoking hot.
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange
1964 GMC 1000 series,custom, 305E, sm420
sstock is offline   Reply With Quote
Old 11-09-2019, 07:01 PM   #12
oldtrux
oldtrux's Avatar
i think it was called brigade blue
a factory color 507,537 with white roof
just my guess
Old 11-09-2019, 10:31 PM   #13
markeb01
Senior Enthusiast
markeb01's Avatar
When I swapped in bucket seats, I built a full panel behind the seats out of 1/8" ABS plastic covered in diamond tufted marine vinyl. I subsequently redid the entire insides with full door panels and full size diamonds:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 11-09-2019, 10:53 PM   #14
bigmoe
bigmoe's Avatar
just my guess
Yes it's the 1965 Brigade Blue but it's base/clear.
Old 11-11-2019, 10:42 PM   #15
bigmoe
bigmoe's Avatar
Here's that 04 F150 back wall panel painted and installed. It's pretty sturdy and the two bolts into the existing brackets on the back wall hold it nicely. I have two L brackets in each lower corner as well. I've ordered some 1/8" ABS bendable sheet plastic to form into the corners.
Why is my pic upside down?
Old 11-13-2019, 10:49 AM   #16
SCOTI
SCOTI's Avatar
Perhaps a better view......
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-30-2019, 11:41 AM   #17
bigmoe
bigmoe's Avatar
I got the corners finished. I bought .093 12 x 24 sheets of plastic (Kydex V) off of Ebay. I made cardboard templates. The Kydex I was able to form in a curve using some heat from a heat gun. There was some color variation so I sprayed it with the same vinyl paint I used on the centre section. I have Honda Odyssey door seals that have the extra lip on the inside and was able to slip the plastic into that lip.
Old 11-30-2019, 07:20 PM   #18
oldtrux
oldtrux's Avatar
bigmoe,that looks great!nice job
was the 04 fi50 a regular cab or does it matter?
Old 11-30-2019, 11:07 PM   #19
bigmoe
bigmoe's Avatar
Donor was a regular cab but I never checked others to see if it was the same.
