Shifter linkage bushing
Hi guys,
My shifter has a lot of slop when put/putting it in gear. After looking around is there supposed to be a bushing where the rod attaches? The rod is only held on by a cotter pin on the backside. Does anywhere know where to source that piece? Thanks for any help! ![]() Last edited by Bahn112; 12-14-2019 at 01:32 AM. |
![]() Join Date: May 2010
Re: Shifter linkage bushing
Definitely not correct. That almost looks like a throttle rod.
Here are a couple pictures of the original on my 69. I'm not near the truck to confirm, but I think there's a rubber grommet in the hole in the arm on the shift shaft with a steel bushing in the hole in the grommet. Last edited by FirstOwner69; 12-14-2019 at 02:51 AM. |
![]() Join Date: Nov 2018
These grommets and bushings are available from ClassicParts.com as part numbers 91-062 and 91-065 (I think you need 2 of each). I just ordered a few for mine.
The bushings down at the transmission are also available from CarId.com, Chevrolet part number 3975132, which supersedes 3748357. I ordered 12 of them, and I believe you need four. I figured for their cost of shipping, I'd make the extra 2 sets available for about $12 (which would include postage). I'll do that after I know they work ![]()
1970 C10 LWB Stepside 1971 Dodge Dart 1993 Buick Roadmaster Estate Wagon |
Is the rod upside down?
Here's a picture of the correct assembly.
Old member
That's the 3 speed his is auto.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
What is this "automatic" that you speak of?
![]() Well, nonetheless, the rod orientation is the same, so it appears his in upside down.
Looks like i'll need to take a closer look at the whole shifter/rod assembly... this whole thing is frankensteined together so it's not surprising if something didn't get put upside down or messed up over the last 50ish years.
Edit: OOPS, this is for Camaros. I'll look for a truck version.
This is what Classic Industries. Much like the original except for the threads on the rod. Should work OK though. https://www.classicindustries.com/product/sw429.html Last edited by FirstOwner69; 12-15-2019 at 12:58 AM. |
Here you go! A few extra parts but has what you need.
https://www.classicparts.com/1967-72...tinfo/91-428/# As stated above, yours may just be upside down. Last edited by FirstOwner69; 12-15-2019 at 01:10 AM. |
After taking a look at the provided pics and then looking at my truck it does indeed appear to have been installed upside down sometime in the past. Thanks for all the help guys! Cheers!
Seems all the problems on my truck are "repairs" that had been done in the past. Most of these trucks would be better off if people just left them alone.
#13 | |
![]() Join Date: Nov 2019
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side Last edited by maverickmk; 12-16-2019 at 12:28 PM. |
#14 | |
Shift Tube Control Grommet: https://www.classicparts.com/1947-76...ctinfo/91-062/ Shift Tube Control Bushing: https://www.classicparts.com/1967-78...ctinfo/91-065/ Clutch & Bellcrank Attaching Clip: https://www.classicparts.com/1960-81...ctinfo/90-851/ (if you don't want to use cotter pins) You also need a backing washer to go behind the clips or cotter pins. Don't know the size off hand, but typical hardware store item. This looks like the 91-062 & 91-065 already assembled. I didn't see these when I was hunting earlier. https://www.classicparts.com/1947-76...tinfo/91-062B/
#15 | |
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
