Old 12-14-2019, 01:23 AM   #1
Bahn112
Shifter linkage bushing
Hi guys,
My shifter has a lot of slop when put/putting it in gear. After looking around is there supposed to be a bushing where the rod attaches? The rod is only held on by a cotter pin on the backside. Does anywhere know where to source that piece?
Thanks for any help!
Bahn112 is offline   Reply With Quote
Old 12-14-2019, 02:37 AM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Shifter linkage bushing
Definitely not correct. That almost looks like a throttle rod.
Here are a couple pictures of the original on my 69. I'm not near the truck to confirm, but I think there's a rubber grommet in the hole in the arm on the shift shaft with a steel bushing in the hole in the grommet.
FirstOwner69 is online now   Reply With Quote
Old 12-14-2019, 07:32 PM   #3
jcwren
These grommets and bushings are available from ClassicParts.com as part numbers 91-062 and 91-065 (I think you need 2 of each). I just ordered a few for mine.
The bushings down at the transmission are also available from CarId.com, Chevrolet part number 3975132, which supersedes 3748357. I ordered 12 of them, and I believe you need four. I figured for their cost of shipping, I'd make the extra 2 sets available for about $12 (which would include postage). I'll do that after I know they work
1970 C10 LWB Stepside
1971 Dodge Dart
1993 Buick Roadmaster Estate Wagon
jcwren is offline   Reply With Quote
Old 12-14-2019, 07:35 PM   #4
garyd1961
Is the rod upside down?
garyd1961 is offline   Reply With Quote
Old 12-14-2019, 07:52 PM   #5
jcwren
Here's a picture of the correct assembly.
1971 Dodge Dart
Old 12-14-2019, 10:37 PM   #6
Andy4639
Old member
Andy4639's Avatar
Wink Re: Shifter linkage bushing
That's the 3 speed his is auto.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-14-2019, 10:42 PM   #7
jcwren
What is this "automatic" that you speak of?
Well, nonetheless, the rod orientation is the same, so it appears his in upside down.
1971 Dodge Dart
Old 12-15-2019, 12:17 AM   #8
Bahn112
Looks like i'll need to take a closer look at the whole shifter/rod assembly... this whole thing is frankensteined together so it's not surprising if something didn't get put upside down or messed up over the last 50ish years.
Old 12-15-2019, 12:48 AM   #9
FirstOwner69
Edit: OOPS, this is for Camaros. I'll look for a truck version.
This is what Classic Industries. Much like the original except for the threads on the rod. Should work OK though.
https://www.classicindustries.com/product/sw429.html
Old 12-15-2019, 12:59 AM   #10
FirstOwner69
Here you go! A few extra parts but has what you need.
https://www.classicparts.com/1967-72...tinfo/91-428/#
As stated above, yours may just be upside down.
Old 12-15-2019, 08:21 PM   #11
Bahn112
After taking a look at the provided pics and then looking at my truck it does indeed appear to have been installed upside down sometime in the past. Thanks for all the help guys! Cheers!
Old 12-15-2019, 09:03 PM   #12
tj1970cst
Seems all the problems on my truck are "repairs" that had been done in the past. Most of these trucks would be better off if people just left them alone.
tj1970cst is offline   Reply With Quote
Old 12-16-2019, 11:59 AM   #13
maverickmk
maverickmk's Avatar
I have a manual that is sloppier than . . . well, let's just say it's bad. I tried to use the part numbers you have listed here and wasn't able to find stuff for my 3 on the tree. Any links to the parts by chance?
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 12-16-2019, 12:23 PM   #14
jcwren
Rod to shift lever grommet (3975132): https://www.carid.com/atp/shift-link...pn-jo-119.html
Shift Tube Control Grommet: https://www.classicparts.com/1947-76...ctinfo/91-062/
Shift Tube Control Bushing: https://www.classicparts.com/1967-78...ctinfo/91-065/
Clutch & Bellcrank Attaching Clip: https://www.classicparts.com/1960-81...ctinfo/90-851/ (if you don't want to use cotter pins)
You also need a backing washer to go behind the clips or cotter pins. Don't know the size off hand, but typical hardware store item.
This looks like the 91-062 & 91-065 already assembled. I didn't see these when I was hunting earlier. https://www.classicparts.com/1947-76...tinfo/91-062B/
1971 Dodge Dart
Old 12-16-2019, 12:30 PM   #15
maverickmk
maverickmk's Avatar
Awesome, thank you very much.
