01-04-2020, 02:59 AM | #1 |
Lift question
Hello everyone, I have some lift kits questions I would like some advice on. I have a 72 k10 with a 6 inch lift and blocks in the rear. I’m looking at either a shackle flip with 2 inch lift springs, a 4 inch lift springs with 2 inch blocks ( mainly for better ride?), and then obviously 6 inch springs. This is a daily driver that gets used to haul and tow, and just about everything in between. What choice would everyone choose and why? Thanks for the input in advance.
Posted via Mobile Device |
01-04-2020, 01:09 PM | #2 |
Re: Lift question
Offroaddesign.com
01-04-2020, 02:00 PM | #3 |
K5Camper
Re: Lift question
Yep go talk to the guys at ORD. Shackle flip and springs would be your best bet for overall ride quality. They can give you the right combo of shackle flip and spring to get what you want.
I'm running an ORD flip out back with stock rear springs and the rear axle ride quality is great when combined with Bilstein shocks.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
01-04-2020, 02:39 PM | #4 | |
01-04-2020, 02:55 PM | #5 |
K5Camper
Re: Lift question
What axle wrap? But in my case with a 5.3 that might be putting 300hp out at the crank and a truck that wieghs 6,500 pounds or higher my truck isn't going to have too much of an issue with spring wrap.
01-04-2020, 03:28 PM | #6 |
Re: Lift question
never ever had probs with axle wrap wit my s. flips.
if you haul and tow and your springs are in good shape, i would do a 4" shackle flip with a small block to level you up. i wore out a set of lift springs reeeal fast hauling my camper and towing my quad trailer. flips and blocks would be a whole lot cheaper than new springs anyways and your ride will be smoother with stock springs than lifted ones |
01-04-2020, 04:20 PM | #7 |
Re: Lift question
offroad design has got TONS of my money over the years for my truck or builds for friends .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
