03-24-2015, 11:56 AM | #26 |
Registered Loser
Re: Power steering with GMC V6?
My question is, why hasn't Captainfab started making these?
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
03-24-2015, 12:10 PM | #27 |
Registered Loser
This is the PS pump bracket I bought off ebay. I have no idea if it's correct or not because I changed my motor plans when I found out the motor wouldn't fit back in (easily) after I bagged my truck.
03-24-2015, 11:33 PM | #28 |
60-66 Nut
Two reasons. One is finding pulleys that will work and second, I simply don't have the time with working 70-80 hrs a week every week.
03-25-2015, 10:52 AM | #29 |
The old Webshots link dies, so I had to shift EVERYTHNG over to photobuckets - Oh Joy!
Here are the pictures of my OEM mount setup, not the tie into the engine mount bolts.
http://s1299.photobucket.com/user/jb...23904108567829 |
03-25-2015, 11:59 AM | #30 |
Awesome pictures especially for someone new like me. I love the paint job also. Maybe someday I will paint my engine. Thanks a lot for posting these:-)
Greg |
02-17-2017, 11:19 PM | #31 |
I know this is a really old post but I don't know anything about the GMC v6s other than the PS brackets are relatively hard to come by. I have found a big truck with the brackets(a/c) as well. I have heard the big truck brackets are somewhat different. Does this mean they will not work on the smaller trucks? I appreciate any advice
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
02-18-2017, 07:21 AM | #32 |
[QUOTE=1774btcrew;7862195]I know this is a really old post but I don't know anything about the GMC v6s other than the PS brackets are relatively hard to come by. I have found a big truck with the brackets(a/c) as well. I have heard the big truck brackets are somewhat different. Does this mean they will not work on the smaller trucks? I appreciate any advice[/QUOTE
Big truck brackets? What truck do you mean? Canyoutake a picture of it? Posted via Mobile Device |
02-18-2017, 01:29 PM | #33 | |
ron |
02-18-2017, 01:49 PM | #34 |
Here is a big truck V6 with power steering. I've seen them mounted high up as well as off to the side, like this one. I don't feel it would fit a light duty pick up.
MusicMan70 1961 GMC Suburban |
06-04-2019, 12:41 PM | #35 |
Does anyone know if someone is actually making these brackets yet and if the double pulleys for the fan are more accessible or someone has found an alternative source part that would do the job?
I would like to get power steering, but I would also like to steal the hydraulic pressure for a brake booster set up as well (hydraboost). Thanks! |
06-04-2019, 02:13 PM | #36 |
AP; check out Rockdrillers build here;
http://67-72chevytrucks.com/vboard/s...=453161&page=4 He’s using a hydro boost on the V6 and made his own PS pump set up. Far as I’m aware no one is making any brackets.
06-05-2019, 10:22 AM | #37 | |
10-22-2019, 08:24 PM | #38 |
He is a picture of my low miler 64 GMC 1/2 ton.
Seems my pump is a different design to what I am used to seeing. Also, does anyone know of rebuilt kits to service the power cylinder and control valve, these are leaky little devils? Steve
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange 1964 GMC 1000 series,custom, 305E, sm420 |
10-22-2019, 11:38 PM | #39 |
60-66 Nut
The cylinder and valve are basically the same as was used in the Corvette's up until '81?
11-20-2019, 11:43 AM | #40 |
Thanks Captain, but finding it hard to get the right pump seal kit. I'm thinking it is a saginaw unit but did GMC's use a medium duty truck pump? This is not what you typically see on 1/2 ton trucks.
Steve
11-20-2019, 12:16 PM | #41 |
All the power steering seal kits are showing for GMCs with V6s on the Rockauto site
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
11-20-2019, 09:16 PM | #42 |
I see that and am skeptical if they are indeed for the medium duty pumps, I ordered a couple kits and will see if they are right or not, will report back but have a hunch they will fit the other smaller saginaw pumps that are more prevalent in chevy vehicles.
11-21-2019, 01:50 PM | #43 |
IIRC, Oldsmobile and maybe others also used that pump in the mid-60's. I had researched the part numbers at one point and found the Olds models it was used on but have no idea where that is now. I can get you the original GM part number for the pump if that will help.
Bob
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
11-21-2019, 08:31 PM | #44 | |
Steve
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange 1964 GMC 1000 series,custom, 305E, sm420 Last edited by sstock; 11-22-2019 at 10:11 AM. |
11-22-2019, 11:47 AM | #45 |
As of the 1964 GMC parts book (printed in Sep 63), the part number for that pump was 5686708. That might get you pointed in the right direction with someone who isn't afraid to break open a book instead of just punching numbers into the computer. A quick search on the internet shows it was also used on both Olds and Pontiacs so restorers of those makes might be a source of information also. So far, the only thing not leaking on mine is the pump, I suppose that day is coming.
Bob
11-22-2019, 10:31 PM | #46 |
Thank You Sir
11-23-2019, 11:54 AM | #47 |
You're welcome! If I find anything, I'll get it posted and let you know.
Bob
01-12-2020, 05:42 PM | #48 | |
I have 1960 GMC with a 305A v6 and I am slowly gathering parts for my power steering addition. I notice that the tricky part is the double groove pulleys for the crank and water pump. Would anyone know if I would need 305v6 pulleys or if other pulleys work from other engines? The water pump ones for SBC's look really similar, but searching ebay, everything says SBC for the cranks. Thanks for any advice or tips. Also, @MusicMan70, the bracket you modified to install your pump, do you remember what company made it / part # ? Thanks, Scott |
01-15-2020, 09:20 PM | #49 |
AngryPirate; Here is a link to an eBay listing for a similar bracket.
https://www.ebay.com/itm/SBC-Power-S...pe!92881!US!-1 I have not investigated whether SB pulleys would work but my guess is a no.
