01-17-2020, 02:31 PM | #1 |
4x4 Radiator Shroud Question
Did all 67-72 4x4 trucks have the 4x4 specific radiator shroud?
My 67 with a 327 currently has the shorter fan shroud. I haven't had any overheating issues in the few years I've owned it, but if it is supposed to have one I may work on doing that to prevent issues in the future. When looking at my current shroud, I can see where having a deeper (by 3"?) one would work better. Thanks, Steve/NH |
01-17-2020, 04:38 PM | #2 |
20' Daredevil (Ret)
Re: 4x4 Radiator Shroud Question
Can't say for sure, but I bet they all came with the deeper shroud. For maximum efficiency, the fan blades should be right at the end of the shroud. I have read half-in and half-out is best, or just inside the end of the shroud. If yours is 3" away, it can't be pulling all its air through the radiator as it should.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
01-20-2020, 09:59 AM | #3 |
The shroud and radiator are currently out of the truck, but it may be even more than 3 inches between the fan and the outside edge of the shroud.
I have read that the 4x4 motors were set back several inches compared to the 2WD trucks, which explains the different shrouds being used. So now I am thinking that all 4x4s would have used them. My truck was made up from both 4x4 and 2WD trucks, so that would explain how it ended up with the shorter shroud. As I mentioned, I haven't had any overheating issues yet, but I haven't sat in any long summer traffic backups or moved any heavy loads either.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke Lariat 2007 BMW X3 2023 BMW X3 M-Sport 2020 BMW 540xi M-Sport 1995 Harley FLSTC |
01-22-2020, 10:58 PM | #4 |
the motor on 4x4s is farther back than 2x4s, so they do have a specific shroud just for 4x4s.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
01-22-2020, 11:59 PM | #5 |
Here is the NOS one I put on my truck (showing sticker) - I can take a picture of the installed shroud (fan side) and check the distance on my '72 4x4.
01-23-2020, 03:00 PM | #6 |
Thanks for the picture of the label 646870SS, with the part number I did a little more research and that would be the correct shroud for my 67. I was able to verify it on GMPartsWiki here: http://www.gmpartswiki.com/getpage?pageid=21326 (starts at bottom of page).
Below is a picture of what I have now, and based on comments it is clear that I need the deeper shroud. One of the tabs is broken and I was going to repair it before putting it back in, but now I think the best thing to do is track down the OEM part. Thanks to all for the help.
01-23-2020, 04:04 PM | #7 | |
20' Daredevil (Ret)
Have you considered also adding a clutch fan? Well worth it IMO. If you're interested you can search for more info, or if you like I can pass along a few details for you.
01-23-2020, 05:54 PM | #8 |
Here are the pics of mine. It is an original 4x4 truck with the NOS fan shroud. The one photo looks deceiving - the fan is in the shroud about 3/4" total so it is tucked in but this way it draws air with all that room in the front - the fan being so far back - it doesn't stick out from shroud. Hope this helps. I am not running a clutch fan, just the original one and it stays very cool. It is an air conditioning truck as well. Also running the original fan spacer - I think it is an 1-3/4".
01-23-2020, 10:49 PM | #9 |
lmc sells them, if you were closer i got 2 extras, but shipping would kill the deal.
01-24-2020, 09:17 PM | #10 |
Those pictures are great 646870SS. I'm now surprised I haven't had any issues with overheating with the wrong shroud in place.
Stocker, no, I haven't considered a clutch fan for my truck, although I am familiar with the advantages. I have already media blasted and painted the one I have, so for now I will just concentrate on getting the correct shroud. I'll be posting a WTB as soon.
01-27-2020, 12:40 PM | #11 |
I used a 4/4 shroud since my V8 is mounted in the 2WD straight 6/4x4 SBC location. My Derale 17118 18" 6-blade clutch fan fits perfectly. Shroud is LMC P/N 32-2826.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
01-27-2020, 10:17 PM | #12 |
How is the quality of the ones from LMC? I have an aftermarket from classic industries I don’t really care for. It’s more of a hard fiberglass than plastic.
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
01-28-2020, 09:04 AM | #13 |
I'm happy with my LMC shroud. The mounting holes lined up well, and the plastic is rigid enough to keep it's shape.
