Old 02-05-2020, 06:16 PM   #126
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Daughters 68 step...
Originally Posted by hooverfish View Post
Andy, keep up the good work !
Love following your build, esp. because you post so many PICTURES !
Thanks. I got the dash back in and hooked up some old 56 Chevy horns to it today. They will hear the horn when it blow's!
I ordered a 112" speedometer cable also today for it. It showed 2 listings for a 68 truck so I got the longest one since I put the 700-R4 in it.
https://www.youtube.com/watch?v=W7X0r1n0Bgs
https://www.youtube.com/watch?v=dtArhmoYMXY
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-07-2020, 10:17 PM   #127
Andy4639
Old member
Andy4639's Avatar
Productive day in the garage. It was 40* when I got up so I moved the 68 into the garage. Lot nicer to work inside warm than outside in the cold. I did do some work out side though.
I got both inner fenders installed. I had to clean the drivers side up first. I wire brushed it the primered then painted it. I got new tail lights installed as well.
Old 02-07-2020, 10:20 PM   #128
flashed
Its looking great Andy , you have been busy .
flashed is offline   Reply With Quote
Old 02-07-2020, 10:25 PM   #129
Andy4639
Old member
Andy4639's Avatar
I got the wiring finished up on the internal regulator and cover on. No more external regulator.
I didn't use the jumper wires, I took the brown wire straight to the alternator. Took the red wire off the old regulator and ran it straight to the new alternator.
Much cleaner and less connections to go bad. I used the Buick alternator with 94amps.
I installed a oil filler tube also.
I have both door mirrors on the way also.
Later I'll do the head light relays.
Old 02-08-2020, 12:17 AM   #130
Boog
laying low
Boog's Avatar
So she's rolling with no AC? Or is that to come later? You mentioned possibly a wood flatbed for it. I thought you'd probably go with a short wheel base stepside since it was originally a stepper. Does your daughter have any preferences for her truck? Did you decide against the 60/40 seat?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-08-2020, 08:50 AM   #131
Andy4639
Old member
Andy4639's Avatar
As for right now no AC but I have the pulleys installed so when I do add it though. It will either be a Classic air system are a under dash unit. I'm looking real hard for a GM under dash unit for my ramp truck now but not had any luck.
Yea I had thought about a wood flat bed but not going to happen. I'm suppose to be going in the morning to look at a stepper for it complete. The weather here is not cooperating at all though. We are under freezing rain & snow today had bad storms all week long with flooding. The bed is 3hrs away so I'm not sure when I will go. My daughter has her input on all of it but I'm the one buying it so I have final say!
As for the seat I had the 60/40 but it was so nasty I gave up on it. The drivers seat was fine but the passenger side was so nasty it just wasn't going to clean up well enough to use. The more I cleaned on it the worse it looked. It just kept smearing into it.
Right now the original is in it but I went this past week and got a full bench out of a 91 like my ramp truck. I taking it to have the cleanup shop get it ready. I'm hoping he can do a better job than I did on the other one.
I may have to recover it but for the price I got it for I can't complain. Time will tell.
Old 02-08-2020, 11:57 AM   #132
Boog
laying low
Boog's Avatar
You know I’ve not heard of anyone shortening a long step box. Single wall and flat sides should be a easy quick deal provided the long panels are decent. Measure cut drill holes pretty much. No splicing?
Boog
primer is finer
Old 02-08-2020, 05:04 PM   #133
Andy4639
Old member
Andy4639's Avatar
Yes there are a couple of threads on here about doing it. I had thought of doing it until I found the bed I'm getting for $450.00 with a good tailgate to.
This thread talks about it the way I had decided to do it. Make the center cut in the bed and the fenders would cover it up for the most part.
http://67-72chevytrucks.com/vboard/s...d.php?t=756616
Old 02-10-2020, 06:51 PM   #134
Andy4639
Old member
Andy4639's Avatar
Got the exhaust done this morning and I cut the bulk connection out of the wiring harness and put a fender stud mount on the radiator support. I now have 12 volts to tie into for head light relays and any thing else I may need later on.
https://www.youtube.com/watch?v=5NILbgGjFKg
Old 02-13-2020, 01:37 PM   #135
Andy4639
Old member
Andy4639's Avatar
Talking Re: Daughters 68 step...
Mirrors are on the 68. Made me some backing plates out of left over sheet metal I had from the rear cab corner stuff.
Old 02-13-2020, 05:06 PM   #136
Andy4639
Old member
Andy4639's Avatar
I got the antenna hole welded and reinstalled the cowl with new Stainless Steel hardware. I also got the hood re aligned to. Looks pretty dang good if I do say so myself!
Old 02-13-2020, 06:43 PM   #137
BigBird05
What are you going to use for an antenna, or are you running without a radio?
BigBird05 is offline   Reply With Quote
Old 02-13-2020, 06:55 PM   #138
Andy4639
Old member
Andy4639's Avatar
No radio right now. I have something in mind but I need the bed first.
Old 02-14-2020, 10:27 AM   #139
cornerstone
cornerstone's Avatar
Nice work Andy!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 02-14-2020, 10:31 AM   #140
Andy4639
Old member
Andy4639's Avatar
Originally Posted by cornerstone View Post
Nice work Andy!
Thanks, this isn't going to be any kind of shinny show truck, just a nice everyday driver. I've never done this much work to a truck like this but over the past 30 some years on here reading and following directions of everyone I felt as though I could handle it. So far so good. My good friend Bill who's shop he let me use up until Jan 31,2020 was a blessing.
Old 02-14-2020, 08:19 PM   #141
Andy4639
Old member
Andy4639's Avatar
Well I started pulling the old cab sealer out today and got it all cleaned up to install the new sealer tomorrow. Wire brushed it good and have it wiped down. My friend is going to let me barrow his double gun to do the 2 part sealer. Hope it all goes well.
First time the truck has been out side in the sun light.
Old 02-15-2020, 04:15 PM   #142
Andy4639
Old member
Andy4639's Avatar
Ok I pulled it back out and wiped it down good with mineral spirits this afternoon. Let dry good and while I was letting it dry I cleaned the hood and windows up.
Took the mineral spirits on a rag to the hood. Made a world of a difference. I'll do the top after a few day to let the sealer dry good. The sealer isn't perfect but it should keep the water out.
I hope!!!!!
Old 02-16-2020, 05:54 PM   #143
Andy4639
Old member
Andy4639's Avatar
Went to Canton Ga today and picked up a short step bed from member Flashed.
Good meeting you finally John.
Hope we can do some more trading in the future.
7hr round trip wasn't bad.
Got to do some cleaning up and some minor repair work but it should be a good match for the truck.
Old 02-16-2020, 07:03 PM   #144
Getter-Done
Getter-Done's Avatar
That's a great match bed and cab combo.
It's almost like they have been waiting to meet up
Great progress.
84 Chevy K-20
Old 02-16-2020, 08:06 PM   #145
Andy4639
Old member
Andy4639's Avatar
Great progress.
Yea they should marry up just fine.
Old 02-16-2020, 11:58 PM   #146
flashed
Andy , it was nice to finally meet you after following you on here for many years and just missing meeting you at ya'lls picnic a couple years ago . Come back down anytime , Im always bringing in trucks and parts .
Old 02-17-2020, 09:30 AM   #147
Andy4639
Old member
Andy4639's Avatar
Thanks, it was great meeting you as well sir. Hope we will cross path's some over the summer at some shows.
Old 02-19-2020, 04:27 PM   #148
Andy4639
Old member
Andy4639's Avatar
Went by the transmission shop that built the 700-R4 for me. Asked about wiring up the torque converter. They told me all I needed was the 4 prong connector that goes on the side of the transmission and a brake light switch for cruise. Put 12 volts to it and it will lockup in 4th anytime it's over 45MPH. The brake switch will knock it off also. I also ran a toggle switch so I can manually turn it off if not needed.
Old 03-02-2020, 01:29 AM   #149
Andy4639
Old member
Andy4639's Avatar
I drove it to the end of the street and back!
https://www.youtube.com/watch?v=R_uvkP18lYg
Old 03-02-2020, 12:09 PM   #150
Boog
laying low
Boog's Avatar
Super.
Boog
primer is finer
