Old 05-27-2020, 10:05 PM   #276
randy500
Re: Crew Cab build preview...
Picked up a 6 speed trans for this yesterday, g56 from a 2007 from behind the 6.7 cummins so it should have the higher overdrive ratio. Can’t wait for it to arrive and get it installed. These nv4500’s have super wide gear spacing.
randy500 is offline   Reply With Quote
Old 05-27-2020, 10:26 PM   #277
Getter-Done
Getter-Done's Avatar
That sounds Like the way to go.
Keep us updated with (likes or dislikes)
This may be my new (Search)
84 Chevy K-20
Old 05-28-2020, 10:39 AM   #278
randy500
Will do on he updates. I hate swap trans right now as this one works perfect, i hope its worth the effort.
Old 05-29-2020, 01:10 AM   #279
burnin oil
The g56 is very much worth it. Its like replacing a 3spd with a 4spd. Really nice for pulling loads also.
burnin oil is offline   Reply With Quote
Old 05-31-2020, 08:41 AM   #280
burnin oil
How's the swap coming along? Once the G56 goes in it will be a totally different ride.
Old 05-31-2020, 10:19 AM   #281
randy500
The trans is shipped, its coming from Alabama, i would guess it will be here this week.
I have been doing some planning like reading up on assembly disassembly, i will open it up for inspection before install.
I have a dana 80 3.54 posi from a 2nd gen dodge that i will install at the same time, I'm tearing that down today and dropping the housing off Monday to have it narrowed. That was a future project but since i will need rear driveshaft work for the trans and likely the rearend swap i decided to do the rear at the same time.
Old 06-01-2020, 12:52 PM   #282
randy500
This dana 80 is massive, its really hard to tell how massive it is until you have to handle the parts. The difference is more than the difference from a 12 bolt to a 3/4ton dana 60, its huge.
Old 06-05-2020, 08:43 AM   #283
randy500
Transmission arrived today. This thing is huge. Seems to be in good condition, I took the shifter off and looked inside. Can’t see everything but what I could see looks good.
I was pleasantly surprised to see it came with the slave cylinder. The slave rod I believe is shorter on a g56.
They really cleaned it up nice which is a real time and mess saver.
Old 06-05-2020, 04:52 PM   #284
Madkidd007
Madkidd007's Avatar
Yea you’re in big boy league now. I remember when I was at Chrysler, they definitely are no joke
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 06-05-2020, 06:12 PM   #285
randy500
Good see your still around.
Picture doesn’t do it justice, its next to a table I build steering columns on, its the same size as the table.
Old 06-05-2020, 06:42 PM   #286
CG
BlahBlahBlah
Beast Mode! Dang that sucker is ginormous!
Old 06-08-2020, 11:58 PM   #287
randy500
I cleaned the garage so I can get the truck on the lift for the trans swap, it’s still prob a half day of moving stuff to get it inside but it’s doable.
Got my parts order from ORD. Spring plates, u bolts and traction bar kit.
Old 06-09-2020, 12:05 AM   #288
kehstr
kehstr's Avatar
If you would not mind when you do the swap. Get a picture of the 2 transmissions side by side. I would like to see the size comparison.
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 06-09-2020, 08:37 AM   #289
randy500
For sure will do that.
I’m concerned it won’t fit and side by side pic will help me look for clearance problems before I install it.
Old 06-10-2020, 04:03 PM   #290
randy500
I have been thinking a rack would be handy for picking up 20’ steel at the steel yard. I also think i can haul a bare frame on it so i picked one up today. Its also the type that is wider for a canopy underneath. A friend gave me a vintage canopy so this will work with that.
Old 06-10-2020, 05:18 PM   #291
CG
BlahBlahBlah
Nice, are you going to keep it long or modify it to fit your bed?
Old 06-10-2020, 11:29 PM   #292
HeloCrewChief
HeloCrewChief's Avatar
I got to meet Randy in person yesterday as he is going to restore my console for me. Super nice and helpful guy. I’m all over the place with different Car and house projects and he pointed me in the right direction. Saw this crew cab in person and it is a sight to see. A dream truck for me as I’m a Cummins fan and have had 4 of them. Phenomenal craftsmanship.
1970 C10 to K20 conversion
1974 GMC Jimmy
1968 50th Anniversary Short Bed
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
HeloCrewChief is offline   Reply With Quote
Old 06-11-2020, 10:12 AM   #293
j_cst_10
j_cst_10's Avatar
Excellent build, I went through several pages of it. I have a 2wd 72 C20 that I converted several years ago to a Cummins/5spd set up and it's a blast to drive. Need to change my Dana 60 4.10's to some 3.55's but beyond that I wouldn't change a thing.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual
1972 Cheyenne Super Short Bed 557 Med Olive DK olive
1970 K5 Blazer Dark Gold
1966 Coronet 440 35k mile survivor
1991 Suburban 2500 454/4L80E 2wd
1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9"
j_cst_10 is offline   Reply With Quote
Old 06-16-2020, 03:32 PM   #294
randy500
Drug this 71 K10 home last weekend.
Old 06-16-2020, 05:40 PM   #295
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks like a great start for another one.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
