Old 06-02-2020, 08:22 AM   #251
oldman3
oldman3's Avatar
Re: Starting a 52 Chevy 3100 Project.
Glad you got it on the road, enjoy...Jim
oldman3 is offline   Reply With Quote
Old 06-02-2020, 08:34 AM   #252
8man
Glad you're driving!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 06-02-2020, 09:18 AM   #253
gigamanx
Gorgeous truck. That's a nice feeling to be on the road again! I had the crappy eBay steering column and wish I just sprung for the nicer one too. Still drove ok, but was sloppy and made some rattles when I went over bumps.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 06-02-2020, 10:12 AM   #254
28TudorAZ
28TudorAZ's Avatar
Originally Posted by Zippi View Post
Sweet looking ride man. I had problems with my doors not wanted to latch all the time. I tried these door latch repair clips and my doors work great now. $4.50 a pop unless your just wanting new latches.
Thanks. I have thought about those.
Thanks!!!
Thanks!!!
Thanks!!!! The steering column was awful. The shifter never was right and was really sloppy. The electronics inside were bad. I was so happy to get rid of it. Also I like your Model A project. I will be getting mine back in my garage soon. You should share your progress on thehamb. Here is a picture of mine.
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085
Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133
28TudorAZ is offline   Reply With Quote
Old 06-02-2020, 10:15 AM   #255
joedoh
joedoh's Avatar
what a great feeling it is to drive something you worked on from start to finish! does your dad like it? or does he love it?
Old 06-02-2020, 10:18 AM   #256
28TudorAZ
28TudorAZ's Avatar
He loves it. He is wondering when we can get the A/C done so he can drive it. It only hit 108" over the weekend.
Old 06-02-2020, 10:27 AM   #257
joedoh
joedoh's Avatar
haha yeah driving a tin can with a steel interior in that heat is a real life sapper.
Old 06-02-2020, 12:33 PM   #258
gigamanx
Model A looks awesome!! I tried to post on the Hamb and they said my build wasn't welcome because its not an original hotrod. I thought of Killbillet but it seems like that forum really isn't very active. So, I ended right back with my crew here on the 49 truck forum and started a YouTube channel to work on the build.
Very much enjoying the next chapter of hot rod life.
Old 06-03-2020, 07:44 PM   #259
28TudorAZ
28TudorAZ's Avatar
That sucks. I have seen builds close to yours on there. Maybe they are anti LS1? Funny thing. Building my Model A gave me the confidence to build the truck. The Model A was driving though when I got it but I had to go through the whole thing. Here is a pic when I first got it. It has had everything replaced. Engine, transmission, steering column, front end, dropped I beam, 8.8 ford rear end, seats, 4 wheel disc brakes, wheels/tire, gas tank, interior, 32 grill/hood and wiring.
Old 06-03-2020, 07:48 PM   #260
28TudorAZ
28TudorAZ's Avatar
So I am having an issues with the turn signals lights staying on constantly and not flashing. I have replaced the flasher unit with an LED one and the emergency flasher lights work fine. I have swapped the flashers around to see if the issue followed the flasher and it does not. Any ideas?
Old 06-03-2020, 09:40 PM   #261
joedoh
joedoh's Avatar
its how you have your column wired, there are two ways to wire it and when the lights stay on constant it needs to be the other way. it has to do with the taillights, if you have a separate turn only bulb and a separate brake only bulb, you wire it one way. most GM use a combination turn/brake bulb, so it needs to be wired the other way. the instructions for your column detail this, for whatever reason I think aftermarket wiring harnesses always have it wired the wrong way for a GM out of the box.
Old 06-03-2020, 10:47 PM   #262
28TudorAZ
28TudorAZ's Avatar
So this is inside the column or the wires at the bottom wire harness? I did find a work around, I put some wire on the flasher and switched the wires opposite and it works. I can pull the wiring harness box off the firewall and switch the wires but it is a pain. I would like to fix it right so I dont have to have wires on the flasher.
Old 06-04-2020, 12:16 AM   #263
joedoh
joedoh's Avatar
neither, its your wiring harness that has the wiring change.
make sure you test your workaround with all conditions, turn signals, brake lights, park lights, etc. the way electrical systems work in cars and trucks is ANY path to ground. since the bulbs are grounded on one side you can think of any bulb as a path to ground through the + wire, because when it isnt energized the ground will travel through the filament.
if your workaround works in every case, it could be your harness is wired wrong. but 9 times of 10 and I have heard about this more than 10 times, the harness wiring at the column is to blame.
Old 06-04-2020, 09:50 AM   #264
28TudorAZ
28TudorAZ's Avatar
Unhappy Re: Starting a 52 Chevy 3100 Project.
So everything works as expected when I swapped the wires. I already tested everything. Its going to be a huge pain to pull the fuse panel and swap the wires. Oh well its gotta be done.
Old 06-04-2020, 05:42 PM   #265
joedoh
joedoh's Avatar
thats great news! so the fusebox was wired wrong?
Old 06-04-2020, 06:12 PM   #266
28TudorAZ
28TudorAZ's Avatar
It must be. The emergency flasher works fine just not the turn signals. I just put wires on the end of the flasher to test and it works. I stuck some tape on it and just shoved it up there for now.
Old 06-11-2020, 04:04 PM   #267
28TudorAZ
28TudorAZ's Avatar
So yesterday I took it by the guys house who I bought the truck from. He thought it was pretty awesome. I found out more history on it. He actually got the truck from his uncle when he was 16 about 30 years ago. He said the last time he rode in it was when he was 16 so I took him for a ride. He also said his uncle had passed away quite a while back and took a picture and sent to his dad. He said his dad also loved it and was glad that it went to a good home. Here is a picture of it in front of his house.
Old 06-11-2020, 04:51 PM   #268
8man
Nice reunion.
8man-aka Robert
Old 06-13-2020, 12:59 AM   #269
joedoh
joedoh's Avatar
thats a gorgeous truck!
i was thinking about your flasher problem, try extending the wires but hooking it up normally. it shouldnt really matter on a two prong flasher which prong is in which hole, its just a bimetal strip, it could be one of your prongs isnt touching?
Old 06-25-2020, 02:26 PM   #270
28TudorAZ
28TudorAZ's Avatar
Could it because I have LED lights?
Old 06-25-2020, 03:25 PM   #271
Tempest67
Tempest67's Avatar
Yes, your LED's could be the cause, as they do not provide enough resistance in the wire to activate the flasher.
You will need to install a resistor into each signal light.
If you have a couple of 1157 (dual filament) sockets, try testing them with standard 1157 bulbs and see if that solves the problem
Tempest67 is offline   Reply With Quote
Old 06-25-2020, 03:28 PM   #272
28TudorAZ
28TudorAZ's Avatar
It works now with the wires switched. Just saying that maybe it would work either way if I wasn't using LED lights.
Old 06-27-2020, 01:30 AM   #273
dsraven
LEDs have less draw so the flasher unit will flash slow if at all. Try an electronic flasher, it may work better than the cheap step sister bimetallic style that relies on current draw to heat the bimettallic strip.
Old 07-01-2020, 11:15 PM   #274
28TudorAZ
28TudorAZ's Avatar
I already have an electronic flashter. LED's only worked wired one way. I am thinking if I didnt have LED lights it wouldnt matter and it would work. Oh well I will swap it the wires at some point.
Old 07-01-2020, 11:15 PM   #275
28TudorAZ
28TudorAZ's Avatar
Put the headliner in tonight.
