#51 | |
Re: The more I learn...the more puzzled I become!
Woody |
#52 |
![]() Join Date: Feb 2016
Thanks for all the photos. I can already see I will be getting some nylon washers to put on my arm rest pivot bolts. Rattle prevented!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#53 |
BlahBlahBlah
Those seats are awesome! Curious where the material came from, and is it actual automotive grade? ... I cant say enough about how cool it is.
#54 |
#55 | |
Woody |
#56 |
Wow those seats look great!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
#57 |
#58 |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
If the Sunbrella seat fabric is as good as the awning fabric I have used for years, you will not wear it out. Great stuff.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
#59 | |
Woody |
#60 |
BlahBlahBlah
Im not looking to use the same pattern you used on your burb, but I looked through something like 1400 plus samples of their material on the Sunbrella site and I didnt see yours there.
#61 | |
Woody |
#62 |
Hey Woody, just wanted to update you on the springs...I did end up going with the standard rate small block springs in mine 6102/6101 and finally got everything buttoned up yesterday. The ride is SOOOOOOOO much better! I still have a bit of tuning to do on my adjustable Fox shocks, but the truck is infinitely better to drive. I did the front springs along with new sway bar bushings and in the back, did the springs with new trailing arm and track bar bushings.
With your 3rd row, you will probably want to run the HD springs in the rear if you'll be driving the truck fully loaded.
1972 C20 Suburban 1964 Corvette Coupe 1997 Lexus LX450 |
#63 | |
![]() Woody |
#64 |
I took the Beach-Burban on a family vacation to the Central Coast of California about 3 1/2 hours from home...the longest non-stop drive I've done with it. Other than the temperature gauge issue I'm having, it worked flawlessly! My wife and I met the rest of the family at the Air B&B we rented in Arroyo Grande (just South of Pismo Beach) but for day trips we loaded all nine of us into the Burb and even had room for gear. We got a lot of "thumbs-up" and people wanting to ask questions where ever we went...even with the rough looking exterior paint! Even wrangled a few strays for the local ranchers! The temp gauge is puzzling...but I posted a separate thread for that!
Woody |
#65 |
The Older Generation
Looks like a good time was had by all. A lot of smiling faces... ![]() LockDoc
#66 |
Looks great Woody....love seeing them get used properly!!
#67 |
Sometimes...I am the cause of my puzzlement! Awhile ago, I finally pulled the trigger and ordered the parts for my "spring" project...and I'm not sure why, but I felt like I stumbled into a "one and done" ordering situation when I found everything I was looking for while scanning through LMC's online catalog. Price wise it made sense, as I also added some items I will be needing in the future (door and window seals plus more) so I ended up getting free delivery.
I am partially happy with my decision, especially with the front springs...as these were listed for a big block, and without raising my ride-height, they keep my front end from diving down like the old ones allowed. It stays pretty much flat when making exaggerated turns (not that I plan on "auto-crossing" with it), but it is a big improvement. The new front bump stops won't have to work as hard as the old ones (uppers were flattened away to nearly nothing, and lowers had traveled into the spring retainer plate enough to sheer the edge nearly all the way through). I was also able to order OEM style rubber bushings for both the tracking and trailing arms (originals looked pretty sad) as well as the rear bump stops (which looked pretty good but were hard as rocks!). I think I messed up with the rear springs, though. I went with the variable-rate springs (same part number for 1/2 ton or 3/4 ton) but shyed away from the HD, as I thought it might end up pushing the rear of body up more than it was. As it is now, the new springs give me the exact same ride-height that I had with the old springs, and they do feel comfortable on rough roads and dips...but that's without a load (other than a full 45 gallon tank and 3 bench seats). My skepticism arose when I looked underneath and saw that the same 3 coils were compressed just as much as my original variable-rate springs were compressed??? I will put some miles on these and see if all is well...and I can always order a set of the HD springs if need be (lesson learned). Thank you to all the members that gave advice...especially Richard and Greg (FLYNAVY)! You both suggested the HD, so I've got no one to blame but myself (which is a good thing!). I do want to "fess up" and say that I had my mechanic buddy provide the labor, as I want to help his business rebound after the shutdowns nearly put him into "early retirement"...but in the pursuit of being 100% honest, I'll add that my body doesn't appreciate laying on the ground under vehicles anymore! Darn old age!!! Woody |
#68 |
Great post Woody. I think most of us have been there!
Paul
#69 |
I had the standard drop springs in rear and changed to the HD springs and it was night and day better ride quality.
#70 |
Hey Woody, sorry about the rear springs...I didn't realize you had a 45 gallon tank as well. Definitely going to want those HD springs back there....at roughly 6.5 lbs/gallon, thats almost 300 lbs in fuel alone. Add the third seat and any occupants...
Anyway, full disclosure, I paid a shop to do my rear springs and trailing arms as well. My issue was (well, besides laziness) that my jack stands were maxed out and BARELY gave me enough room to droop the axel to the point where tension was off the springs. After messing with the arrangement for an hour, and needing to use a breaker bar on every bolt, I decided to throw in the towel, and took it to a local off-road shop that had a decent reputation. They had the truck for way longer than they should have, and someone syphoned my entire gas tank clean, but at least the work was done correctly, and they didn't charge much.
#71 |
Thanks Paul...I am envious of those that can do so much of their own work...I used to be one of those guys (my youth and lack of funds were the main motivators), but now I'm grateful for being able to utilize the member's knowledge (and spend a little money without impacting the family!).
Woody |
#72 |
#73 | |
My buddy got all my stuff done by the end of the next day (including welding a crack in one of the rear spring "cup" retainers)...and I didn't lose any gas! Let's see: 45 gallons X $2.85 a gallon (CA prices ![]() ![]() Woody |
#74 |
Hey, I found this from being over on the WMB thread. Looks like we're missing out on a lot that must have happened over the past few years. I started writing what follows below, and then looked at the date and realized how long it's been. So what I have to say below might not be relevant, but I will put it here anyway:
I'm not one to drop the "L" word, but I love seeing a rig bring a family together like this. That sunny yellow and, yes, even the surfboards ; ) That picture of all of the pretty, smiling ladies in it is priceless. You are doing all of the right things to be able to enjoy it - even if you have to order things like the rear springs twice. I probably would have first tried the variable rate ones too. There's a good chance you can advertise them here and somebody with a smallblock, 2 rows, and less than 10,000 gallons of gas will be glad to have them. If I may offer some advice... Your Suburban looks great even with a couple rough spots on the exterior. The paint shows well and you can get rust fixed and paint spotted in. You can get paint code spray cans from these guys and spruce up the interior a bit if you want: https://www.automotivetouchup.com/ I just think that you could lose a year or even two of having your Suburban in somebody's paint shop. And losing even one summer of being able to drive around with your grandkids would seem like too much. Maybe you can do some spot touch up and wait to get the full repaint done later. None of my business, but sharing that rig with your family seems the very best way to use it in my perspective. |
#75 |
Hello LT7A…thanks for responding to my thread! For some reason, I started writing other threads instead of keeping this one going? Probably because I had specific questions about certain tasks at hand and wanted the title to reach the intended targets???
Anyway…you are spot-on with your analysis, and I have actually taken your advice in advance of you saying it! There is nothing wrong with driving the Beach-Burban with its natural patina…or even with spotted-in paint or primer showing. Besides making good decisions like taking custom paint off the table, I’ve made some poor choices (for good reasons, I thought) and I’m still working through those to get me back on track. First is the EFI (written up in a separate thread) which needs a few more tweeks to get it dependable…and second is finishing the interior as I saw another members “woody style” headliner that I’ve got an excellent woodworking friend helping me out with. After those are to a point that I can put my seats back in, my plan is to drive it a lot…because this past year has bummed me having it sit so much (and the grand kids keep growing, so my time is running lower with each passing day). Thanks for the encouraging words! Woody |
