06-01-2020, 03:07 PM | #1 |
Mustang II power steering issues
Hoping I can get some thoughts on an issue I am having with my Mustang II power steering (from CPP). It's installed on my 56 3100.
Issue is turning right (mainly when stopped) it binds and very difficult to turn the steering wheel. Turning to the left when stopped no issues at all very smooth. I have flushed the system twice, and early on replaced the power steering pump. Any thoughts? |
06-01-2020, 08:05 PM | #2 |
Re: Mustang II power steering issues
I'd say have someone turn the steering wheel while you look under the truck to see if there is any thing physically binding the steering gear.
06-01-2020, 08:25 PM | #3 |
Thanks. I have done (Sunday afternoon) that and nothing is binding movement. The interesting thing is there are times when it moves freely and other where it nearly locks up. It's feels like the pump is fighting me (like a break pedal).
06-02-2020, 10:41 AM | #4 |
Hmmm, well, honestly, anymore than I just said would be guessing on my part. Are there any metal flakes or other bits in the fluid when you bled out the system?
06-02-2020, 11:57 AM | #5 |
No junk in the fluid, and I have changed it twice. May have to break down and find a local shop to look at it.
06-03-2020, 01:04 AM | #6 |
If there is no mechanical binding and/or interference, look into the steering linkage or hydraulic components.. If the pump is having a problem, you'd have binding in both directions.. I suspect you have a valving issue or other problem in the rack & pinion unit..
06-03-2020, 12:22 PM | #7 | |
06-25-2020, 05:55 PM | #8 |
Still having issues turning right, but better after flushing system. Trying to work with CPP on fixing the problems or replacing the unit.
But have a question. Can anyone tell me what the tube that runs from boot to boot does? What is it's function? From what I can tell is it goes no where. The boot pulled off one time and put it back in place with the tube that just fits into a rubber socket. |
06-26-2020, 10:16 AM | #9 | |
06-26-2020, 11:58 AM | #10 |
Thanks. That makes sense. Appreciated.
