Old 07-25-2020, 05:19 PM   #26
FAKKY
Re: No C-notch
Took her for around block - 1st ride in 4 years ---- rode awesome ....... even without shocks ..... But I do have a power steering leak as well as a "grinding" sounds .... again definitely PS ..... I thought I had addressed this ....... any ideas on how to track down issue/fix .... i.e too much pressure versus ???
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 07-25-2020, 05:43 PM   #27
joedoh
joedoh's Avatar
Re: No C-notch
woop woop! congrats!
bleeding power steering is usually turning it lock to lock a few times. if you have too much pressure and the steering feels like you are turning on ice, thats common on a MII setup with a GM pump and you can change the pressure shim at the back of the pump, jegs sells a shim kit.
Old 07-27-2020, 08:45 AM   #28
FAKKY
Re: No C-notch
Thanks.
Yeah not a MII setup ....... GM astro hydro and GM dakota IFS
Im away for a few weeks on a family trip ....... if this is all I have to sort out when I get back shouldnt be too bad ...... well that and get the seats bolted down
Appreciate the input guys.
Old 07-27-2020, 12:18 PM   #29
joedoh
joedoh's Avatar
Re: No C-notch
Originally Posted by FAKKY View Post
Thanks.
what a goober I am, I said MII but what I meant was rack and pinion. sorry. your dakota is rack and pinion.
the rack and pinion doesnt need the pressure of a steering box, so the reducer shim is still what you would need. but I am not sure how the pressure reducer would affect your hydroboost? maybe ask the guys with gm power steering boxes, hydroboost, and rack steering what they did.
I had a truck with waaayy overassisted power steering, you could steer with a pinky. it wasnt a rack, it was an older GM steering box with a newer GM steering pump, but a shim fixed it.
Old 07-27-2020, 12:23 PM   #30
FAKKY
Re: No C-notch
gotchya
Im going to check all teh fittings when i get home as well as high/side low side and just the general once over ...... and might buy a PS pressure tester just to see where I am at.
Then assume this is what you mean
https://www.summitracing.com/parts/brg-899001
Old 07-27-2020, 12:54 PM   #31
joedoh
joedoh's Avatar
Re: No C-notch
yessir, thats it
your leak could be overpressure pushing fluid out of the rack seals.
