07-27-2020, 01:58 PM | #26 |
Re: Restoring my dash pad
07-27-2020, 02:01 PM | #27 | |||
Carl |
07-27-2020, 04:18 PM | #28 |
I did this back in the mid-'80s, before the internet, and this site, and Period-specific vendors like LMC.
I took the OEM dashpad off the cab and chipped the very brittle chips of old Fawn vinyl from the foam backing. I was careful not to gouge it. All the old vinyl came off with a putty knife -- eventually. I had just had a pro seat shop do the upholstery on my seat in Saddle vinyl. I saved a strip of material ~7' x 1.5'. I sprayed 3M 77 contact cement on to the foam and then the back of the vinyl, and worked it up from the ''leading edge''around to the back, carefully stretching as I went. I had to tuck in sort-of "hospital corners" at the ends, on the undersurface. Excess was trimmed with a razor knife. I bolted it back in the dash and it's still there in my '68 C/10 Stepside. I tried a blue one from Brothers, for my other truck ['71 GMC Jimmy] years ago ['90s] and it looked OK, until I tried to cinch up the last nut on the extreme [left] drivers side. It wouldn'd start. Had to pull it off, only to discover that that stud was an FD --all slag and no threading. How it got assembled, past inspectors [if any] IDK. I sent it back for a replacement, and they were good about it. But I had to install it twice. Only reason I didn't use my own method on the blue truck was the under-foam was compromised on the OEM dash pad.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 07-28-2020 at 02:36 AM. |
07-29-2020, 12:54 PM | #29 | |
07-29-2020, 12:58 PM | #30 |
Before stripping the vinyl
07-29-2020, 01:03 PM | #31 |
Here I am getting all the old vinyl off with a heat gun. Too much heat Isn’t good though as you can see in the 4th picture.
07-29-2020, 02:41 PM | #32 |
Fill those low spots with the Gorilla Glue, it will foam up overnight and you can sand it flush next day.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
07-29-2020, 03:25 PM | #33 |
07-29-2020, 04:01 PM | #34 |
07-29-2020, 04:08 PM | #35 | |
07-29-2020, 07:52 PM | #36 |
I lucked out. My OEM foam was still good. [If a little stiff.] On the second truck, the Jimmy, it was already bad when I got the truck. PO had tried to hide it under a rug-like top dash pad from a Squarebody. Looked like Z%)@. So I just bought one from a vendor -- with mixed results.
You might try keeping a spray bottle with water on hand and spray before you join the two 3M 77-ed sides. Gives you a little leeway to pull it back and set it right before they grab together and bond. To keep my corners from unravelling, I punched holes in the gathered ''darts'' and slammed leather rivets in the tucked vinyl. Never see it though.
07-31-2020, 02:02 PM | #37 |
Received the dash pad cover from astroballs (Mitch) today and let me say it looks amazing. The quality of work is second to none. He even sent me some padding to help cover the imperfections in my original pad. I was worried about tucking the ends of the cover but he already covered that and has it stitched in. I'm very happy with his work!
07-31-2020, 02:49 PM | #38 | |
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
07-31-2020, 06:52 PM | #39 |
Proprietor of Dale's Corner
That looks very nice. I can't wait to see it installed.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-31-2020, 09:07 PM | #40 |
Gorilla glue is on and now waiting overnight...
07-31-2020, 09:55 PM | #41 |
Carl,
I just sent you a PM, ...but the pics are looking good. You may find (as I PM'd) after first sanding you still have some low spots, but just add more glue and repeat. Sure it adds another day to the process, but that's what I ended up doing. Kevin
07-31-2020, 11:06 PM | #42 | |
Carl |
08-01-2020, 02:39 AM | #43 |
Exactly!
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
08-01-2020, 02:25 PM | #44 |
Carl,
I sent you a PM on this, but figured I'd add here for others who may be following along... The glue used for the vinyl was this (brush on contact cement). I would normally have used spray adhesive (ie. 3M Trim adhesive) but the brush on let me apply it right where I wanted. One can (a pint) of this was good for the dash pad. https://www.amazon.com/00271-Weldwoo...s%2C151&sr=8-2
08-01-2020, 02:34 PM | #45 | |
08-01-2020, 08:35 PM | #46 |
I got it all sanded down and decided to pad it a little more. Here is a few more pics.
08-01-2020, 10:15 PM | #47 |
I'm really excited to see your results. I am considering this for my truck too.
08-01-2020, 10:34 PM | #48 |
I hope I can do this cover justice. I will finish it up in the morning and put some more pics up. I don't think it will be too hard, Mitch has already done all the stitching and basically all i have to do is make sure i get it on straight.
08-02-2020, 11:44 AM | #49 |
Finish pics, straight forward and easy install. Like I said in a previous post, Mitch has all the hard work done. Basically all you have to do is clean your old dash pad up and glue this cover on. Very happy with the results and have a quality dash pad. I have around $85.00 in total cost in the cover and materials needed to do the project. The pint of glue was $15.00, gorilla glue was $5.00, and the vinyl cover was $57.00 plus shipping I think.
08-02-2020, 11:56 AM | #50 |
Couple more!
