Old 08-22-2020, 03:14 PM   #1326
Gregski
Gregski's Avatar
Re: A '54 named Busty
Originally Posted by LT7A View Post
...What paint did you use on the A-Arms, they look nice...
thanks found a brush on can of the same ACE brand black paint I've been spray painting with so I went with it cause I did not have to mask much and just ended up with a black forearm ha ha
Note: a quart was way way too much as my mima says a pinch would have done it
Gregski is offline   Reply With Quote
Old 08-22-2020, 03:42 PM   #1327
Gregski
Gregski's Avatar
everyone's a ganghstah 'till it's time to do ganghstah stuff
Old 08-22-2020, 03:57 PM   #1328
Wide Open
Those turned out nice. What do you do this time? Not the wire brush method right?
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Wide Open is offline   Reply With Quote
Old 08-22-2020, 04:08 PM   #1329
mongocanfly
mongocanfly's Avatar
Yeah...we got hurricanes pushing in...we always get crazy weather when they do
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-22-2020, 04:22 PM   #1330
Gregski
Gregski's Avatar
wire wheels FTW
Old 08-22-2020, 04:27 PM   #1331
Gregski
Gregski's Avatar
We'll see your gusts of wind, and raise you a couple EARTHQUAKES and a dozen Hell Fires !!!
Old 08-22-2020, 04:53 PM   #1332
mongocanfly
We get a few quakes here, but not like yall...to wet here to worry much about fires....
we got hurricanes and tornadoes and humidity and skeeters
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-22-2020, 09:03 PM   #1333
Gregski
Gregski's Avatar
then I went out and rented this completely useless coil spring compression kit
and after badinkering with it for an hour or two I decided to give up on the passenger side cause clearly installation is NOT the reverse of removal, ha ha
Old 08-22-2020, 09:05 PM   #1334
Gregski
Gregski's Avatar
THIS MUST BE WHAT HELL LOOKS LIKE !!!
Old 08-22-2020, 09:10 PM   #1335
Gregski
Gregski's Avatar
... but we still had beer so we pressed on
I decided to do the driver side My Way (hang the upper control arm, conjoin the spindle to it with the lower control arm attached only at the front to the spindle) then insert coil spring and gently jack the whole contraption up and whalla job done!
Old 08-23-2020, 03:42 PM   #1336
Gregski
Gregski's Avatar
and today we completed the B Side of the Symphony of Destruction
join us next month as we overcome our money problems and set out to do the brakes
Old 08-24-2020, 08:33 AM   #1337
texxxan
texxxan's Avatar
Man, that looks so good. Well worth the effort of cleaning everything and painting. Awesome job!!!
texxxan is offline   Reply With Quote
Old 08-25-2020, 10:01 PM   #1338
Gregski
Gregski's Avatar
much appreciate it, thank you, it was a ton of dirty work
Old 08-25-2020, 10:08 PM   #1339
Gregski
Gregski's Avatar
oh give me a brake!
Old 08-25-2020, 10:09 PM   #1340
Gregski
Gregski's Avatar
so since the front pads looked like they had plenty of meat on them I decided to see if I can salvage the front brakes and save a few duckets
Old 08-25-2020, 10:10 PM   #1341
Gregski
Gregski's Avatar
they actually cleaned up real nice and even passed the drop test, ha ha
Old 08-25-2020, 11:30 PM   #1342
Gregski
Gregski's Avatar
the passenger rotor cleaned up real nice as well
Old 08-25-2020, 11:31 PM   #1343
Gregski
Gregski's Avatar
and the mandatory stare and compare
Old 08-25-2020, 11:33 PM   #1344
Gregski
Gregski's Avatar
honestly the only thing wrong with these rotors was that the passenger side had a broken lug, simple fix really
Old 08-25-2020, 11:36 PM   #1345
Gregski
Gregski's Avatar
the calipers were next to get some love
Old 08-25-2020, 11:37 PM   #1346
Gregski
Gregski's Avatar
Ridges? We don't need no stinkin' ridges!
Old 08-25-2020, 11:41 PM   #1347
Gregski
Gregski's Avatar
and just like that we knocked off another 2 seconds off our quarter mile putting us well under 45 seconds, ha ha
so I used a sanding disc to take the ridges down, but here I just show you how I get every inch of bristles off my wiring wheels
Old 08-25-2020, 11:43 PM   #1348
Gregski
Gregski's Avatar
chics dig smooth calipers, just sayin'!
Old 08-26-2020, 08:29 AM   #1349
daddyjeep
daddyjeep's Avatar
That is a whole lot of work right there. Now are you going to get some of that fancy red caliper paint on there?
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 08-26-2020, 08:53 AM   #1350
8man
I like the brake work.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
