#26 |
Re: A freebie! 1986 C10 Longbed
Something interesting!
#27 |
#28 |
#29 |
#30 |
Front end disassembled and being prepped for the new spindles!
![]() Cut 1 complete coil out of the spring, about 2” additional drop over the 2.5” spindles. ![]() Spring and spindle reinstalled. ![]() My dumb ass forgot to check the brake package before ordering the spindles...turns out this truck actually had the 1” rotors! So, perfect time to convert to JB5 rotors and calipers! ![]() Caliper and new pads installed! I’ll have to wait until tomorrow on the hoses, they ended up being a day out. ![]() Since the front end isn’t complete yet, enjoy another glorious rear end shot! ![]() |
#31 |
Fancy indeed! Nothing wrong with a good rear shot.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#32 |
#33 |
That is very nice! Do you have any information on the kit you used?
#34 |
Thank you! And yes, I do! Overall, this is about a 4.5” front/6” rear drop. Current tire size is 235/70R15, I will likely keep that front size and go 275/60R15 in the rear.
The drop spindles are Classic Performance CLP-CP4s4 2.5” drop spindles. https://www.summitracing.com/parts/clp-cp4s4 The coil springs are stock 1/2 ton V8 springs with 1 complete coil cut as seen in the pictures, equal to about 2” additional drop. The rear leaf springs are the stock 3+1 spring pack, the overload spring is intact and no leafs were removed. The axle flip kit is UMI Performance UPI-6410, with a 6” drop. https://www.summitracing.com/parts/upi-6410 The shock extensions are UMI Performance UPI-6411. https://www.summitracing.com/parts/upi-6411 The sway bar relocation kit is Classic Performance CLP- 6372LSB. https://www.summitracing.com/parts/clp-6372lsb |
#35 |
Just here to tinker
![]() Join Date: Jun 2008
Great work so far! Very nice stance.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
