10-25-2020, 12:06 AM | #576 |
Re: Let's see some 73-87 1 Ton Dually Pictures!
That looks like 6" front lift.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
10-25-2020, 12:07 PM | #577 |
Looking around for suspension ideas and came across this thread. This is my '77.Turbo 6.0/4l80e
10-25-2020, 12:54 PM | #578 |
Looks clean!
10-25-2020, 01:13 PM | #579 |
10-25-2020, 01:48 PM | #580 | |
I was building my 64's set-up based off of the bolt-in c-notch for the dually when I questioned just how strong things were. I was very surprised w/the decrease of strength. Its easy enough to augument bolt-in notches but it impacts the sheet-metal directly above which I guess is more work than most want to tackle. You should start a build thread for your project when you get the chance.
10-26-2020, 07:03 PM | #581 |
Mine is rated for a little more than one ton. Does it still count?
1989 GMC C7000 TopKick 3208T CAT / Eaton-Fuller 6 speed
Daily Driver: 2005 Chevrolet Silverado 3500 Dually 6.6L LLY Duramax Diesel and an Allison 5 Speed Currently looking for an Action Line truck, specifically 1969-1970, in very good condition. Longbed only, step or fleetside, or flatbed if C30. Must be unmolested (not modded). Last edited by STPETEBLUE; 11-01-2020 at 11:05 PM. |
11-01-2020, 09:46 PM | #582 |
11-03-2020, 04:01 PM | #583 |
chevy truck fan
stpeteblue,
Nice job, the body lines line up very nice . I can't help but imagine it with chrome 22.5's I cracked up after looking at your signature... your "smallest" truck is a 1 ton dually!! nice..... |
11-03-2020, 06:05 PM | #584 | |
Thanks, but I didn't build it. I wish I could say I did.
It was built by a guy named Mike Powell. He does great work. On his website, if you click on the "SOLD" link, mine is the "Ex-Ryder" truck. I like the steelies on in, but Mike showed me a pic of one just like mine with a set of aluminums and I'm really kinda jazzed about that look, now. Quote:
Actually, Sweetie drives a Silverado 1500, so....
Daily Driver: 2005 Chevrolet Silverado 3500 Dually 6.6L LLY Duramax Diesel and an Allison 5 Speed Currently looking for an Action Line truck, specifically 1969-1970, in very good condition. Longbed only, step or fleetside, or flatbed if C30. Must be unmolested (not modded). |
11-08-2020, 12:15 PM | #585 |
My 91 , 33K original miles.
Desert |
11-09-2020, 05:45 PM | #586 |
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
01-06-2022, 10:52 PM | #587 |
Let's see some more! Been a while since this thread has been active. I've started looking for another and having withdrawals from not seeing any.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
01-07-2022, 12:03 AM | #588 |
01-10-2022, 04:11 AM | #589 |
That is a sweet looking dually.
So did you end up buying it?
onlylovematters... ...and, you know, trucks |
01-10-2022, 05:54 PM | #590 |
01-12-2022, 02:23 PM | #591 |
Posted these in another thread last week.
Here is my 85 C30 that I've been building for a little over 2 years. Currently in winter mode as I break the motor in. *Yes it has a hood on it, I was waiting on a backordered release cable that finally came in. |
01-13-2022, 12:39 PM | #592 |
Did you get the rear wheel issue sorted out?
01-13-2022, 11:03 PM | #593 |
One of my 88’s. This ones is an American Vans Conversion. Waiting on a few more pieces, and its going up for sale, as I’m down to only 1 child at home now.
01-14-2022, 10:41 AM | #594 |
01-14-2022, 11:26 AM | #595 |
01-14-2022, 12:21 PM | #596 |
05-31-2023, 12:21 AM | #597 |
Loading.....
A thread worth bringing back from the dead.
Only had it a few days. 86 High Sierra c&c 4x4. Lift and 36’s in the works.
-M7 '69 SWB GMC 5.7 EFI ‘69 C/10 SWB patina survivor ‘71 GMC K20 '72 K5 1-ton gear 468BB ‘86 K30 GMC High Sierra C&C Single Cab '96 SWB Single Cab 5.7 ‘99 SWB Z71 Single Cab '00 SWB Single Cab 5.3 '01 K2500 Yukon Safari 6.0 ‘06 2500HD Single Cab C&C Duramax 4x4 '08 1500 crew '11 2500HD Single Cab Duramax 4x4 |
06-02-2023, 09:25 AM | #598 |
It followed me home?
Couple of mine
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
12-15-2023, 12:43 AM | #599 |
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
12-22-2023, 01:24 AM | #600 |
R.I.P. E.S.L.L.
My 83. I got it about a month ago. It just passed CA. smog inspection after being parked 5 years.
1971 Custom C/20 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
