Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-07-2019, 11:59 AM   #51
DeepOceanStepside
DeepOceanStepside's Avatar
Re: 3 Kids, 1 Wife, and 1 Lonely Blazer
Awesome build!! Subscribed to see future progress
1970 Base Step Side Dark Olive 250 3ott restoration
1972 k5 4x4 250 3ott project
1970 long bed light olive 283 th350 driver SOLD
DeepOceanStepside is offline   Reply With Quote
Old 10-22-2019, 07:46 AM   #52
C.I.Blazer
Build looks great. Hope you are still at it!
C.I.Blazer is offline   Reply With Quote
Old 10-22-2019, 01:16 PM   #53
CJM72
I'm still alive and still have the Blazer! Have some small updates to post. Been a busy summer with the kids, but I'm hoping to get it fired this winter. Wiring and coolant plumbing are the major items left to get it running!
CJM72 is offline   Reply With Quote
Old 10-22-2019, 01:39 PM   #54
mkelly
mkelly's Avatar
Great job so far. I am just starting almost the same build. I look forward to your updates and I will probably coming to for questions.
mkelly is offline   Reply With Quote
Old 01-25-2020, 05:27 PM   #55
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice work. Just saw this thread and jumping aboard to learn more about LS swaps into K trucks. How is the clearance between the firewall and the heads?
Old 01-26-2020, 09:03 AM   #56
CJM72
I left my T-case in the stock position, used the Advanced Adapters kit to adapt to a 4l65e. I have about half an inch of clearance at the tightest spot on the firewall. It's just the corners of the heads. Any shorter combination of transmission and I think it would be right. Next clearance challenge is the oil pan to differential. I have worn out stock springs with an add-a-leaf and I probably only have 2 inches right now with the Dirty Dingo cross member. Will likely try to create more clearance by modifying the dirty Dingo cross member and putting a 2" lift in it. It's the cross member itself that would hit first.
More updates coming soon. Fuel system is done. Wiring and cooling systems now. Hoping to have it fired up soon!
Old 01-26-2020, 11:31 AM   #57
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thank you for the details. I’ll stayed tuned. Am tempted by the retro LS motors assembled by Delmo speed shop or Don Hardy and these use adapters to accommodate stock style valve covers, which might contact the fire wall given the added height. Sliding forward sounds like would encroach further on the front diff with the DD xmember.
Old 12-29-2020, 02:54 PM   #58
Racer2172
Nice work, great build.
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692
70 C-30 Tow truck AKA Highlighter
02 Silverado 2500 HD CUCVII Tow Rig/DD
1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800
1980 Buick Regal Dirt Stock car
Racer2172 is offline   Reply With Quote
