Old 01-15-2021, 08:23 PM   #1
rgunlock
rgunlock's Avatar
Would like intermittent wipers in my 78 GMC
I've read a number of threads about this, but it seems to come down to finding an intermittent wiper control module. Seems that the control modules are hard to come by. Does anyone know of a source for these, or an aftermarket solution?
Thanks!
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 01-15-2021, 08:41 PM   #2
kipps
Re: Would like intermittent wipers in my 78 GMC
Were intermittent wipers even an option with the dash-mounted switch?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 01-15-2021, 09:33 PM   #3
Corts60
Just here to tinker
Corts60's Avatar
I believe they had an option for intermittent wipers these years. Instead of the metal square knob for the wipers, there would be a little round black knob with an arrow on it. You turned it to adjust the intermittent. I don't think they worked very well....
Old 01-15-2021, 09:35 PM   #4
Corts60
Just here to tinker
Corts60's Avatar
They looked like this.
Old 01-15-2021, 09:53 PM   #5
Nick_R_23
Nick_R_23's Avatar
Yes, they would look like the picture posted above.
Adding the intermittent portion is pretty easy, as you’ve read. It’s been added to my ‘78 Chevy, and is as simple as finding the module on a parts truck, and the module is plug and play.
As far as I know, the module is not currently being reproduced by anybody, and supposedly they have internal component failures, but I’ve seen them be repaired before. Your best bet would be to find one at a wrecking yard or someone locally parting out one of these trucks, and bring your truck so you can test it easily.
Old 01-15-2021, 10:04 PM   #6
farmall
farmall's Avatar
https://www.summitracing.com/parts/hla-001871061
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 01-15-2021, 11:03 PM   #7
Dead Parrot
I had a 79 Camaro with a switch similar to what Corts60 posted. The intermittent function worked fine until something went wrong and the wipers wouldn't turn off reliably.
Guessing you could expand your parts search to all mid to late 70's GM vehicles and not just trucks. A lot of parts from that era were common across the various GM lines.
Dead Parrot is offline   Reply With Quote
Old 01-16-2021, 09:20 AM   #8
rgunlock
rgunlock's Avatar
There are threads on this site that describe how to add the feature, and there was a member gmachinz that used to repair and sell the control modules so it can be done. The part that isn't simple around where I am (Houston area) is to find a yard that still has 70's era vehicles.
Originally Posted by farmall View Post
Thanks farmall. This is an interesting looking option. Apparently doesn't come with installation instructions or wiring diagram. I'll have to spend some time searching the internet to see if anyone who's added one of these drew up a wiring diagram.
Thanks Dead Parrot, I hadn't thought about checking other vehicle models. Maybe one of the threads I ran across on this site has a part number to search for.
Rick
