07-08-2004, 02:48 PM | #1 |
antenna delete????
Are there cowlings out there with no antenna hole ar do they have a plate to stick in it. i don't have a welder to fill the hole with, and need to do something because i have a french antenna where the fuel filler was..Thanks
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
07-08-2004, 03:02 PM | #2 |
Check out GMTrucks.org
If you can find the cowl off a truck that was radio delete, it will not have an antenna hole. I had one, but sold it for some good money at the portland swap meet last spring.
07-08-2004, 03:10 PM | #3 |
They're pretty rare and usually bring some pretty good $$$ but they're out there.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
07-08-2004, 03:13 PM | #4 |
Then it might just be cheaper to have it welded? i guess i'll go that route i know what kind a price rare stuff can bring. and i not looking to spend a whole lot on this part. if i was restoring to original then i would. thanks for the input
07-08-2004, 03:47 PM | #5 |
i actually have one from a 69 but someone drilled a hole in it for an antenna
'67 c10 350/th350 |
07-08-2004, 04:44 PM | #6 |
I've got one, but it is going on my blazer. Before I found it I was planning on welding the hole, shouldn't be too hard.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
07-08-2004, 05:17 PM | #7 |
The LuvShack Garage
I ALSO WAS LUCKY AND FOUND ONE, GOING ON MY BLAZER PROJECT UNLESS
THE ONE THAT COMES WITH IT IS THE SAME AS MINE, IF SO MINE WOULD B 4 SALE, CHECK BACK IN A WEEK OR 2 FOR THE VERDICT, I HOPE
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
07-11-2004, 10:39 AM | #8 |
Well found a guy at work with a welder, and I now have no more antenna hole. i also stripped it down to bare metal (Aircraft paint stripper....great stuff). and reprimed. thanks again for your inputs
