02-20-2021, 10:34 AM | #1 |
how to protect harness
What is the best way to protect this transmission control harness from the sides of the hole. I'm all ready gonna cover the hole with dynamat which should hold the harness away from the sides of the hole but should I do more? maybe:
Zip tie some leather around the wire loom and I am gonna try and clean up the hole a little today but its still gonna be sharp. Any ideas are appreciated |
02-20-2021, 11:21 AM | #2 |
Re: how to protect harness
A quick Google search turned up this website, https://rubber-grommet.com/ I'd look through here and find something to use to protect the wires from chaffing.
02-20-2021, 11:23 AM | #3 | |
02-21-2021, 11:42 AM | #4 |
Oh, got it
02-21-2021, 11:59 AM | #5 |
How about a Split grommet?
Link below for example there are many different types. Link: https://www.mcmaster.com/split-grommets/ .
02-21-2021, 02:45 PM | #6 | |
Those at McM'carr are certainly a possibility. Gonna finish routing wires through there and see just how many I have then go one of these two routes. thanks again |
02-21-2021, 11:45 PM | #7 |
Old member
Lowes & Home Depot sell a package of rubber insulators for this. You may have to buy several of them though to get enough of the right sizes. They are in the electrical section where the tie wraps are. The boxes have like 8 different sizes in them I bought a couple of packs the other week myself.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-23-2021, 05:19 PM | #8 | |
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
03-04-2021, 02:07 PM | #11 | |
I'm basically finished with wiring and I'm super itchy to wrap and tie-up all this wiring I've done because it looks so bad but I've decided to wait until I've started the motor and installed the instrument cluster so If there are wiring problems I don't have to unwrap everything! Again, thanks all for the advice |
