![]() Join Date: Mar 2006
bench adjustment rod HELP?
The long rod underneath the seat is missing. I found the replacement for the rod but its a cable? anyone use this replacement? thanks Rick
![]() Join Date: Dec 2013
Re: bench adjustment rod HELP?
Using a cable works . This is way more than you need but it will work . $7.99
![]() https://www.amazon.com/YXGOOD-Stainl...90059800&psc=1
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
My seat adjustment rod was busted also. I bought the cable replacement from LMC. Worked out well enough. The rod had been held on with vice grips for who knows how long and it rubbed/rounded the lip down that holds it, and the cable for that matter, in place. A hose clamp slid over and holding it (even if just barely) tight to the post made short work of the problem so it doesn’t slip off. I like that I was able to adjust the length of the cable on the one end, but you could just as easily make your own like was already mentioned. The last picture doesn’t show the adjustable end of the cable, but gives an idea as to what it looks like.
![]() ![]() Join Date: Jan 2005
This is the piece that would originally have been where you installed the hose clamp, although the hose clamp is a resourceful solution.
https://restorationperformance.com/p...ng-retainer-2/ These parts are shown in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=418802 |
