Old 03-01-2021, 11:42 PM   #1
truckdude239
truckdude239's Avatar
387k tahoe gets new diff
Welp finally got tired of listening to the grinding ground of front diff on 387000 mile Tahoe. Picked up this beauty of a differential from local junkyard 22,000 documented miles on the truck will probably outlive the rest of the Tahoe looking forward to i stalling it ina few days
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-02-2021, 08:06 AM   #2
Re: 387k tahoe gets new diff
Old 03-02-2021, 11:14 AM   #3
richards72chevy
richards72chevy's Avatar
Was all them miles racked up on the original motor?
richards72chevy is offline   Reply With Quote
Old 03-02-2021, 04:10 PM   #4
truckdude239
it got a engine and transmission at 369k not suren if trans was orginal but engine was orginal trans was out of and egnine was leaking alot of oil and running poor so i just swaped both for a 150k units
David fuller
2000 Tahoe 5.3l 378
Old 03-03-2021, 12:19 PM   #5
truckdude239
Its in old had had alot of metal shards on drain plug also found my 15 mm swivel scoket I lost 3 year ago when I did engine swap can't believe it rode there that long
David fuller
2000 Tahoe 5.3l 378
Old 03-05-2021, 12:02 PM   #6
hatzie
Moderator
hatzie's Avatar
That's never good to find on the drain plugs.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-10-2021, 02:49 PM   #7
biketopia
Is your hoe a full time auto unit? The front diffs live and die by routine service on the full auto units. You can draw out the 2x4 units a little on fluid changes though. I had co-worker I had to put one in an escalade that looked even worse at 105k because he never changed the fluid.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 03-10-2021, 02:52 PM   #8
truckdude239
Mine does have an auto 4x4 option but I leave it in 2x4 if I'm not in ice or snow I got the truck at 369k so I dont know how well it had been serviced in the past
David fuller
2000 Tahoe 5.3l 378
Old 03-10-2021, 02:54 PM   #9
biketopia
You're good to go now, fresh fluid every 75-100k, if it lives that long and you're golden!
Old 03-10-2021, 02:56 PM   #10
truckdude239
Yup I also filled it with synthetic amsoil 75w90 gearoil
David fuller
2000 Tahoe 5.3l 378
Old 03-11-2021, 11:35 AM   #11
hatzie
Moderator
hatzie's Avatar
I use a laundry soap pump and clear hose on bottles of gear, manual transmission, and transfer case oil but Amsoil really has a good gimmick with the bags.
Old 03-11-2021, 11:43 AM   #12
Warrens69GMC
Warrens69GMC's Avatar
Valvoline has went to them as well
Old 03-11-2021, 12:41 PM   #13
hatzie
Moderator
hatzie's Avatar
It's a really good idea. The packaging is likely a heckuva lot cheaper and it's a lot easier for the consumer to use. Winner all the way around
Even with the soap dispenser and hose it's still a pain in the neck to fill the diffs and transfer case on my 05.
