Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 03-02-2021, 06:37 PM   #1
MASTERBrian
6.2L Tune Up
My 2012 Yukon XL Denali with the 6.2L and AFM is at 97,000 miles. Apparently it's time for plugs and wires. Any input on what is the best option here? I have been looking on Amazon at my options, mainly because it's easy.
What does everyone recommend? At this point she's bone stock.
I see the Edelbrock 22716 Ultra Spark 50 wire set for $69. Are those worth it or just stay with AC Delco?
What about plugs? I planned on AC Delco on that, unless another better option. I don't know if stick with Platinum or Iridium? I think they came platinum, but I'm not sure.
Any other other 100,000 basics to do? All fluids have been changed, except for coolant flush, which I might do when she goes in for next service or airbag recall.
Also, while on the discussion I have a small stutter on my 03 burb with the 5.3L flex. Its been 50,000 since plugs and wires on her, so going to do them as well. Same question on the Platinum or Iridium on it or other option.....I think same plug.
MASTERBrian is offline   Reply With Quote
Old 03-12-2021, 05:14 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: 6.2L Tune Up
In the T900 use Iridium AC Delco spark plugs
In the T800 use Platinum AC Delco spark plugs
There's a TSB from Delco about this. I believe I posted it in my 2005 Silverado thread.
Use Delphi or AC Delco wires. They got you to 97K. The Delphi replacement plug wires I put on my 2005 2500HD at 87K had the exact same markings as the original factory wires and I expect they will last just as long.
Change out the air filter with a new FRAM or Delco paper element if it's been more than 25K or you don't know. The T800 trucks can use the HD Dirtymax filters with deeper pleats in all of the V8 air filter housings. I'm not sure about the T900 trucks.
Change the power steering fluid, brake fluid, axle(s) fluid, transfer case fluid, Dexron VI transmission fluid & WIX strainer, engine oil & filter, and flush the cooling system & refill with 50:50 Dexcool premix. Most folks overlook power steering and brake fluids and they get really nasty.
Make sure you replace the 200°F flexible square refrigerator magnet in the transmission pan with the round magnets that are rated for 300-350°F temps. There's a TSB for this as well but I can't find it at the moment. The proper magnet is the same part as the Allison 1000 transmission behind the 8.1L & Dirtymax uses between the spin on filter and the transmission. Part # 29535617.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
