Old 03-28-2021, 07:07 PM   #1
Andy4639
Old member
Andy4639's Avatar
Question Gear shifter....
Need idea's on how to mount this gear shifter idea.
I bought these last week at the beach. Need to get some idea's on how to mount it. I got a bolt and ordered a set of couplers to extend it up a little higher in the truck. The threads are 3/8" x24. I need some idea's on how to mount it with out having the nut in it's head.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-28-2021, 07:23 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Gear shifter....
Slow cure epoxy?
84 Chevy K-20
Old 03-28-2021, 07:29 PM   #3
72c20customcamper
72c20customcamper's Avatar
Why dont you want a nut inside the head ? My experience is without a nut and locking nut the shift ball will start to rotate . Guess JBWELD would work but without metal threads it will ware out and strip
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-28-2021, 08:24 PM   #4
Mike C
Mike C's Avatar
Fill it full of JB weld. Install a helicoil. JB weld drills and taps. Then it can be screwed down and anchored with a jam nut.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-28-2021, 08:30 PM   #5
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Gear shifter....
I don't want anything to be seen on the outside of it. Not worried about inside it. I didn't want to drill the top of it to do a nut are bolt.
JB weld may be a idea. I also may could use plumbers roll also. It can be drilled and tapped also.
Old 04-01-2021, 08:50 PM   #6
Andy4639
Old member
Andy4639's Avatar
Question Re: Gear shifter....
I temporarily have the skull mounted and wired into the lights. I'm thinking I need to round the wood off and countersink to fit the shifter rod better than the square end.
Old 04-01-2021, 09:16 PM   #7
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I dunno but it looks cool lit up!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 04-01-2021, 10:02 PM   #8
Andy4639
Old member
Andy4639's Avatar
Talking Re: Gear shifter....
Thanks. It should look good with skully sitting beside it.
