Old 05-02-2021, 10:04 AM   #76
mobileortho
mobileortho's Avatar
Re: '50 3600 re-do. Shortening things up!
Pretty much done with the exhaust. I ended up switching from 2.25” to 2.5” pipes. Picked up the straight tubes from a local shop and ordered a Flowmaster tailpipe kit #15802 and Walker SS Quiet Flow mufflers. Cutting it close on the header ground clearance though, got 5” on the driver side & 4.5” passenger but thats with the mustang suspension completely lowered. Will probably raise it up an inch or so.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 05-02-2021, 10:35 AM   #77
dsraven
Drop all the suspension and see what you have for clearance if youre worried. Go from there. Only takes a floor jack and a few minutes.
Old 05-07-2021, 12:00 AM   #78
mobileortho
Really wanted to use the full length headers but they were too low for comfort. I really didn’t want to raise the front up either. This is Much better!
Robert C.
1950 3600
Old 05-07-2021, 07:23 AM   #79
6DoF
6DoF's Avatar
those headers were a tad crazy, good call
6DoF is offline   Reply With Quote
Old 05-11-2021, 12:19 AM   #80
mobileortho
Yeah, if the truck wasn’t lowered they’d be perfect. If anyone needs them hit me up!
Robert C.
1950 3600
Old 05-11-2021, 02:01 AM   #81
Gregski
Gregski's Avatar
I dig the fuel tank
Gregski is offline   Reply With Quote
Old 05-12-2021, 10:34 AM   #82
mobileortho
Originally Posted by Gregski View Post
I dig the fuel tank
Thank you sir!
Robert C.
1950 3600
Old 05-12-2021, 10:35 AM   #83
mobileortho
The front coil overs and control arms have arrived. Hopefully I can get to them this weekend!
Robert C.
1950 3600
Old 05-14-2021, 11:45 AM   #84
mobileortho
The new control arms are wider, gonna have to shim them.
Robert C.
1950 3600
Old 05-14-2021, 12:05 PM   #85
8man
Who made them?
I'm going to lower the 54 and have been looking at front control arms is why I ask.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 05-14-2021, 12:36 PM   #86
mobileortho
Originally Posted by 8man View Post
Who made them?
I bought them off Ebay, but they're part of a kit from CCP.
https://www.classicperform.com/NewPr...COIL-OVERS.htm
Robert C.
1950 3600
Old 05-14-2021, 12:41 PM   #87
8man
Thanks.
Please show the "shimming".
8man-aka Robert
Old 05-14-2021, 12:57 PM   #88
mobileortho
Will do. Haven't given much thought as to what I'll use yet. Not sure if a few washers would do the trick or not.
Robert C.
1950 3600
Old 05-17-2021, 12:06 PM   #89
mobileortho
Thanks.
I'll post a pic later, but the old ball joint space was a perfect fit.
Robert C.
1950 3600
Old 05-17-2021, 12:49 PM   #90
dsraven
stainless steel washers work great. get the large OD with the size of ID you need. a little silicone grease works great to lube and also hold them together for assembly.
the extra width between the pivots may be a nightmare for the alignment guy because it will put the ball joint forward or back from where it may need to be. he can simply move the shims around though. if you use the body fender washer style of washer they will be thin and he can micro adjust the ball joint position by moving the shims as required. ball joint position will affect the caster.
Old 05-18-2021, 08:50 AM   #91
mobileortho
You know, I actually did that on the passenger side but when I moved on the the drivers side I discovered the ball joint spacer was a perfect fit. I didn't feel like disassembling the passenger side so I left it as is! Lol! Also, of note, the spacers have to go on the front of the crossmember. My 1st attempt was on the rear but I discovered that the coil over didn't line up with the mounting holes on the control arm.
Robert C.
1950 3600
Old 05-23-2021, 02:32 PM   #92
mobileortho
Finished with the front coil overs. Disappointed that the sway bar I had laying around wouldn’t fit, it’s about 4” too long.
Robert C.
1950 3600
Old 06-03-2021, 09:09 AM   #93
mobileortho
I just noticed how close the driveshaft is to the rear cab brace. There's only about 2" of clearance. Thinking I can notch this for additional space without causing any structural issues. Am I on the right track here?
Robert C.
1950 3600
Old 06-03-2021, 10:29 AM   #94
dsraven
Lots of builds have notched that member. When you do it may be a good idea to check what you need for space with the rear suspension fully compressed. That way you know you're good no matter what or you know you need to install suspension limiters so you are safe from contact if you happen to hit one of those hidden whoopty-do bumps that sneak up on you.
Old 06-04-2021, 09:56 AM   #95
mobileortho
Thanks for confirming and for the tip.
Robert C.
1950 3600
Old 06-04-2021, 11:37 AM   #96
dsraven
I've seen a few who have used a section of heavy wall tubing to make the notch. Also seen a few who had to notch the back of the cab for sufficient driveshaft clearance. Seen some with a 2 piece driveshaft as well so that the forward section doesnt move up and down when the suspension moves.
Old 06-05-2021, 01:30 PM   #97
mobileortho
The two piece shaft sounds pretty cool. Think I’m going to take the simplest route and cut it.
Robert C.
1950 3600
Old 06-15-2021, 09:38 PM   #98
mobileortho
Picked a a good deal on a chromed grill. Found it on one of the Facebook AD forums. It’s new, never installed but has a very small dent on one of the bars. $300, shipping included.
Robert C.
1950 3600
Old 06-16-2021, 10:29 AM   #99
8man
Nice find!
8man-aka Robert
Old 06-16-2021, 03:55 PM   #100
joedoh
joedoh's Avatar
man that is a nice score.
I really like how you stick with your project without meandering on goals. if it hasnt been mentioned before, you get a lot of my respect for that.
