#76 |
![]() Join Date: Jun 2012
Re: Budget Build 1985 K20
Got the cab and inner fenders in epoxy.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
#77 |
Then put Raptor Liner on the bottom of the cab and on the wheel side of the inner fenders. I also put Raptor Liner on the bottom of the tub and inner fenders of my Jimmy and with well over 10k miles not one chip and still looks great.
#78 |
Good progress. It looks like the raptor liner layer out nicely.
#79 |
Yea it did. Thanks. I am afraid that progress is going to slow down. I got a ton of spring cores around the house to get done.
#80 |
I did get all the body work on the cab done and into 2k primer. Like everything on this truck way more small dents than anticipated. It appeared someone sat on the roof at some point!
#81 |
I also ordered my clear coat and base. It took me forever to decide what SPI clear coat to go with but I finally settled on the Euro over the universal. This is what $1,200 looks like and I’m not sure if it will be enough for the whole truck!
#82 |
Nice work! Yep, looks like a butt size dent.
#83 |
Awesome work, just joining the build!
This K20 is going to be too nice to drive when you're done! I'm a big fan of Raptor Liner, I've been using it for about 10 years.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
#84 |
Thanks!
Thank you! I hope it not to nice to drive but it’s heading in that direction.
#85 |
I tested out the base and clear on the glove box door, ash tray, lower column cover, door have hinges, tailgate hardware and bolts. Everything turned out great. Now it’s time for some bigger pieces.
#86 |
Looks great!
#87 |
Nice work!
#88 |
Fenders, cowl and bumper filler block to 400, washed masked then sealer.
#89 |
3 coats of 029 midnight blue base and 4 coats of euro clear. Turned out really nice. A little bit of dust nibs in the clear that I will need to sand out and just a touch of orange peel. I think a quick buff and onto the doors!
#90 |
Looks good!
#91 |
![]() Join Date: Jul 2006
Love the midnight blue, glad you went that route!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#92 |
Great color!!
#93 |
Thanks! I really like the color too. And it saved me about $500 a gallon going midnight blue over apple red.
#94 |
Didn’t get as much done as I wanted this weekend but me and my shop buddy did get the the fenders sanded and buffed. I just hit the trash with 1000 grit then the whole fender with 1500 then 2000. I then buffed them with a wool pad with cutting compound then hit them with a foam finishing pad and polishing compound they turned out better than I expected. I hope the rest of the rig turns out as good as the fenders did.
#95 |
Great job on the finish work, nice crisp reflections!
#96 |
Finally got the doors and the hood sanded and painted. After the buffer got away from me on the edge of the hood I ended up having to sand them spot in some base and re clear. Ugh! Lesson learned - tape the edges!
#97 |
I also got a new daily!
#98 |
It has been a while since i last updated and i wish i could say that i have made a ton of progress but life gets in the way. I did get the inside of the cab painted, floor pans raptor lined and all finish sanding completed on the exterior of the cab and then i partially tore my achilles tendon. So this is how she sits now.
#99 |
I have started to feel better lately and can kind of get around with out the use of crutches so i have been trying to tackle some smaller projects that i can work on sitting down.
I rebuilt the hyrdobooster i got from a local pick and pull and fixed a EGT probe hole in the headers i plan on using.
#100 |
I also started rebuilding my vent windows. The first task was to weld the pivot stud back on.
