Old 07-18-2021, 07:25 PM   #1
kglowacky
new steering box
Does anyone make a brand new power steering box for my 78 c-10. I have put 2 rebuilt boxes in and I think they are my problem. Very tired of fighting my 1 inch slop in the wheel on the Houston freeways. All my front end suspension components are brand new.
Not sure about trying another rebuilt. The second one seemed to get rid of some of the slop but after a couple 100 miles it is back. cant believe my truck could wear one of these boxes out in this time.
kglowacky is offline   Reply With Quote
Old 07-18-2021, 07:56 PM   #2
Re: new steering box
https://redheadsteeringgears.com/
I’ve heard some people don’t like them because they too much resistance.
Old 07-18-2021, 07:57 PM   #3
Mathew21
Mathew21's Avatar
Very good quality https://redheadsteeringgears.com/
Do you still have the rag joint on your steering shaft? If so have you given any thought to switching to an XJ Jeep steering shaft? It really tightened up my steering. https://www.youtube.com/watch?v=H9C4RdvjPNQ
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 07-18-2021, 07:57 PM   #4
Nick_R_23
Nick_R_23's Avatar
Tough call on new boxes, most are remanufactured. I’ve had the best luck with Napa boxes.
Redhead Steering also makes a box for you:
https://redheadsteeringgears.com/pro...eries-pickups/
Edit: If you keep having repeat issues with boxes, have you verified where the slop is in the system when it feels loose?
Old 07-19-2021, 12:10 AM   #5
kglowacky
not sure what I bought on ebay to replace the rag joint but it was a steering shaft off a jeep. The splines on the box and the splines on the shaft seemed to be a alitttle loose so I went back to a new rag joint.
The more I look and turn turn the wheel looking for sloop the more i believe it is in the box.
Old 07-19-2021, 01:28 AM   #6
Nick_R_23
Nick_R_23's Avatar
Don’t guess, there’s a lot of points where play can be introduced into the steering system. Have a helper lightly turn the steering wheel back and forth in the range that it has play, while you observe where the play is coming from.
Old 07-25-2021, 09:46 PM   #7
v30crewcab
v30crewcab's Avatar
you have to adjust the play in the worm gear first, which is done by loosening the jamb nut on the back of the box were the steering column bolts in, tightening the inner nut which has two holes in it, by putting a punch in one of the holes and using a screwdriver to tighten it til it won't move, then backing off 1/4 inch.
Then you can adjust the top nut and allen until the steering doesn't return to center when driving, and back it off 1/8th turn.
thats the way to do it on the vehicle. the right way is done on the workbench but this works for me.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 07-25-2021, 09:59 PM   #8
kglowacky
I would try this but the rebuilder insist he has been rebuilding these for years and he already adjusted it. I believe his definition of rebuilt and mine are totally different. I think a rebuilt is one where the gears are replaced if worn with all new seals and gaskets. His must be replace seals and gaskets. I pretty much gave up on him. The second time he rebuilt he claims he replaced the gears and the slop did get better but now after a couple 100 miles it is back to junk. I have a hard time believing I can wear out these so callled new gears in 100 miles or less on 2 of his rebuilds. I think my gears are worn and he doesn't have the parts to replace them so he just tightens up the box and gives it back.
Old 07-26-2021, 05:01 PM   #9
K25alive
Borgeson makes a new power steering box for C10s, https://www.borgeson.com/xcart/produ...productid=1805
K25alive is offline   Reply With Quote
Old 07-26-2021, 06:21 PM   #10
kglowacky
anyone tried a borgeson
Old 07-26-2021, 07:15 PM   #11
RodnRudy
RodnRudy's Avatar
I put the new close ratio Borgeson power steering box on my 77 along with their new intermediate steering shaft, bought them thru Summit. I am very happy with the way it drives and steers. Pricey but worth it in my estimation.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 07-26-2021, 08:25 PM   #12
hatzie
Moderator
hatzie's Avatar
Borgeson is top shelf stuff. Their U-joint steering shaft is a 100% drop in.
The Jeep XJ steering shaft is 90% drop in with a few mods needed to make it fit. Jeep uses Saginaw steering boxes and steering columns just like GM.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-27-2021, 04:43 PM   #13
kglowacky
Just talked with redhead. customer service was great. Answered all my questions. So I just ordered a Redhead (NO a steering box). Will update when I get it and install.
Thanks everyone.
Old 07-28-2021, 08:33 AM   #14
Rich84
Rich84's Avatar
Can't wait to hear.. Mine is leaking.
Whats the lead time?
Rich84 is offline   Reply With Quote
Old 07-28-2021, 08:54 AM   #15
1957 Chief
Proud Vet that loves the USA
Totally agree with you brother.
Bubba
1957 Chief is offline   Reply With Quote
Old 07-28-2021, 09:37 AM   #16
kglowacky
same day shipping. Looks like about a week in my hands
Old 07-31-2021, 08:00 PM   #17
Bloodhound
I did a Redhead box with the Borgeson u-joint shaft. Love it.
Bloodhound is offline   Reply With Quote
Old 08-01-2021, 02:27 PM   #18
Street Smart
Street Smart's Avatar
Not sure is it`s relevent, but I put a Borgeson box in my 67 Suburban about 2 years ago. I absolutley love it. I originally had the power assist junk like a corvette in there when i got the truck. I updated it to a rebuilt box from a 80`s C10 box i picked up which was way better but only ok.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 08-01-2021, 05:42 PM   #19
kglowacky
Ordered box on a Monday at my door Sunday morning via Fed Ex . Washington to Houston. will update on install in the next couple days.
Old 08-02-2021, 04:49 PM   #20
kglowacky
well the challenges continue. Installed redhead box went to connect the hoses and the female connection in the box is different then my old box. Called redhead they say I must have a newer box so I need to get new hoses for a 1978 c10. the problem is these are custom hoses to fit my ls1 pump. so I would have to buy new hoses for the ends get them cut and then take these ends and build new hoses. Anyone know if they sell an adapter for this problem? would need a male end of 11/16 18 and and female end the same size and the other hose would be 5/8 18. with the female end the same.
Old 08-02-2021, 05:03 PM   #21
kglowacky
here is the ones I have currently. Need the other type. one is 5/8 other 11/16.
Old 08-02-2021, 06:26 PM   #22
kipps
Here's one option. Purchase new 1978 c10 hoses, and use this fitting.
https://www.dirtydingo.com/shop/prod...oducts_id=1414
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 08-02-2021, 07:56 PM   #23
kglowacky
that's what I am looking for almost. really don't want to put the adaptors on the pump side. Rather find adapters on the box side that way I don't have to buy hoses . I currently have o ring ends (that I removed from my old 82 suburban box that I had custom molded onto the Ls hoses). my new box has inverted flair female connections. My challenge is my o ring threads are American not metric. I bet someone makes this adapter, should be something like inverted flair adapter to a o ring, 5/8 18 on both ends (and the other is 11/16)
Old 08-02-2021, 09:56 PM   #24
Nick_R_23
Nick_R_23's Avatar
CPP makes adapters that go on the steering box.
Old 08-02-2021, 11:10 PM   #25
84 400
Sb 400 club
84 400's Avatar
Could you also order the box for an 84c10? I guess you would have to cover shipping vut then you would have no adapter. I know they are made but hard to find. As suggested above cpp
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
