Old 08-02-2021, 09:13 PM   #1
1969C10LSbuild
1972 factory c10 wheels tire size
Hello, I'm sure this has been asked many times before, so if you know of a link to answer please post it, I have a 1972 c10 at factory height and factory rear wheel wells, what is the widest tire I can fit on it without hitting the tub? Also include wheels size and backspacing if possible I want to maybe stick with like 15x10 torque thrusts on the rear and maybe 295s if possible also may do a 2/4 drop later on. Any help is greatly appreciated.
1969C10LSbuild is offline   Reply With Quote
Old 08-03-2021, 01:43 AM   #2
lil hoodlum
lil hoodlum's Avatar
Re: 1972 factory c10 wheels tire size
Sorry I'm not much help, but great truck and color and I also love torque thrusts rims on these truck...
lil hoodlum is offline   Reply With Quote
Old 08-03-2021, 04:49 PM   #3
1969C10LSbuild
Thanks man, they do look really nice, nice truck btw
Old 08-03-2021, 05:01 PM   #4
With a drop I doubt the 10's will clear up front. Most folks run a 7" or 8" with 245/60 to maybe 255/60. Depending on the drop method, the wheels may interfere with Tie rods ends or require trimming of lower a-arm. Normally a 15x7 with 3.5" backspacing seems to do OK. I do not think in a 15" you will be able to clear more than a 4" backspacing up front regardless. Rears on the 10" seem to do OK with 4.5" backspace with out clearance issues.
Old 08-03-2021, 05:11 PM   #5
1969C10LSbuild
I dont want 10s up front I was thinking 10 in rear and 8s up front I just am trying to figure out if I would be able to run 10 wides and 295s on the rear without having to modify tubs
Old 08-03-2021, 08:37 PM   #6
MikeB
MikeB's Avatar
15x8 rally wheels have 4" B/S and easily clear everything in the front on my 69 C10.
The only issue I've ever had is a BFG Radial T/A 255/70 tire rubbing the front fender lip if you hit a bump during a turn. That was with approximately 2" front drop. However Cooper Cobras are a shade narrower than BFG Radial T/As, and don't rub. Also, and this might make a difference, my truck has 85 C10 spindles.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 08-04-2021, 03:25 AM   #7
The 295s on 10 should clear from what I have seen. Keep back space between 4 and 4.5 inch. To have tire heights balance/look right I would run a 245/60 up front on 7 or 8"
Old 08-04-2021, 06:31 AM   #8
1969C10LSbuild
Thank you
1972, c10, torque thrusts
