09-28-2021, 11:47 PM | #1 |
4x4 front axle swap, 67-86?
Can someone confirm that any 4x4 axle from 67-86 will swap onto a 1970?
Just found out my front axle is junk. Everything except the knuckles out and the housing needs to be replaced. Maybe even the housing. Figured I would look for a better shape entire axle vs rebuild the thing. |
09-29-2021, 03:50 PM | #2 |
Re: 4x4 front axle swap, 67-86?
I can confirm that is correct information for 1/2 ton and 3/4 ton front axles. I swapped a 78 3/4 ton front axle in my 70 Blazer - it required some adapters to handle the brake line fittings if I remember correctly.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
09-29-2021, 04:58 PM | #3 |
69-91 will swap in. But 69 is closed knuckle and 70 is open knuckle but still drum brake. Somewhere around ‘79 the Dana 44 turned into an 8.5” 10 bolt, but either will work and are mostly equivalent in strength. Rumor is 88-91 have 30 spline inner axles same as Dana 44 but I can’t verify.
I swapped ‘86 10 bolt hubs and 8 lug brakes onto my original ‘72 Dana 44 housing and knuckles. On my kids Jimmy we swapped in a complete 8.5” 10 bolt. We also used a ‘79 TransAm limited slip in the front. One interesting thing I found was the ‘86 Suburban outer stubs had two grooves for snap rings so either manual or auto hubs could be used. On the ‘84 in my kids truck, outers had only 1 groove so his original blue knobs wouldn’t work and we swapped in the ‘86 axles since I reused my Dana 44 axles when doing the hub/brake conversion.
09-29-2021, 06:31 PM | #4 | |
I had already done a disk brake kit on my front. Which is why I was going to swap over the knuckles and hubs. Secondly, the one I found is a 10 bolt and not a Dana 44 like I “have now”. I’m quoting because what I have now is junk. I’ll see if I can upload a pic later. My other option is to rebuild my current front end. The parts and labor will probably be way more than the $450. |
10-02-2021, 09:13 PM | #5 |
In ‘85 it should be automatic locking hubs and not full time 4 wheel drive, full time disappeared after 1979 along with the np203 t-case.
Outers are same Dana 44 to 10 built as long as they are both big u-joint. But your original may not be. If you had to you can just buy new outer stubs that would work with manual hubs.
10-03-2021, 09:49 PM | #6 |
Found a front axle from a 86 K10. Looks like it will work. I’m going to try to swap my knuckles on with my hubs and disk kit.
Any advice on how to restore a used axle setup? It has surface rust and I want it looking good. |
10-04-2021, 04:30 PM | #7 |
any axle from '71 and newer will already have disc brakes- there is no need to swap over your knuckles, hubs and brakes unless the axle you're buying is missing everything.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
10-04-2021, 04:39 PM | #8 |
Found a front axle from a 86 for $60. Missing the hubs and calipers. So, will have to swap it all anyway.
