Old 11-22-2021, 05:11 PM   #1
Lord_glum
Brake rotor mystery
Hello,
I am sure there is something that I screwed up but I wanted other opinions.
Parts and pic below. Didn’t post pic as it comes through huge from Dropbox.
My brake caliper is not aligned evenly on the rotor.
Front Brakes
• TIMKEN 8871 seals
• TIMKEN set 3 bearings
• TIMKEN set 5 bearings
• Powerstop AR8600 rotors
• CPP d52 brackets 6087DBK
• CPP modular 2 1/2” drop spindles for 73 to 87 for qa1 control arms
• Wilwood D52 140-11290-R
https://www.dropbox.com/s/t9q2nw0z5h...%20PM.jpg?dl=0
Lord_glum is offline   Reply With Quote
Old 11-22-2021, 06:41 PM   #2
Big Kev-O
Big Kev-O's Avatar
Re: Brake rotor mystery
I think you spindles may not be designed to work with the standard D52 calipers you have listed. If you check the Willwood site and put in the info for a C10 with CPP spindles the only options listed are the 6 piston calipers designed for 13-14" rotors. You should probably call CPP for more info. What is the part number of your drop spindles?
https://www.wilwood.com/BrakeKits/Br...2+Drop+Spindle
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 11-22-2021, 07:52 PM   #3
Lord_glum
Thanks for the input. They should be cpp part number CP30106-4.
My thought is the d52 should work with the brackets.
Old 11-24-2021, 01:20 PM   #4
Lord_glum
Problem solved. Was shipped the wrong calipers.
