Old 12-05-2021, 08:22 PM   #1
FLYNAVY30
Has anyone come up with a good dog divider?
We like to travel in the Suburban as much as possible, the problem is with my 1 year old in the rear facing car seat in the middle bench, he's perfectly positioned for my 16 month German Shepherd to assault him with excessive amounts of "love" via face lickings from the back of the truck.
Has anyone come up with a good solution to keep the pup safely in the back of the truck while traveling?
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
FLYNAVY30 is offline   Reply With Quote
Old 12-05-2021, 09:37 PM   #2
Beach-Burban
Beach-Burban's Avatar
Re: Has anyone come up with a good dog divider?
Hey Greg...During my law enforcement days, our prisoner transport vans had pre-made heavy wire panels installed to keep the "Big Dogs" at bay, so you might want to look at that industry for some ideas? As I recall, that stuff wasn't cheap (the maker was either Ranger or Pro-master???) but there might be less industrial products out there that could also be less expensive?
Woody
Beach-Burban is offline   Reply With Quote
Old 12-05-2021, 10:50 PM   #3
FLYNAVY30
Thanks Woody. Theres definitely a few different materials that would work to build a custom partition from, I'm curious if anyone has found something a little more "off the shelf" that worked well. I'm guessing not but figured Id poll the audience.
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
Old 12-06-2021, 02:48 AM   #4
BAD1916
Could you replace one of the carriage bolts holding the rear plywood down with an eyebolt and secure a rope to that to keep him from getting to the seat? This would probably be easier and more visually appealing unless you are wanting a full divider.
BAD1916 is offline   Reply With Quote
Old 12-06-2021, 08:32 AM   #5
FLYNAVY30
That would probably work, but Id prefer a full divider. The other option is to put his crate back there, but thats a pain every time you want to move something else besides the dog.
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
Old 12-06-2021, 06:20 PM   #6
Beach-Burban
Okay...now I get it, Greg...something someone else has already used. The item I suggested is way too expensive (nearly $400)...but it is actually quite simple in design. If you had a source for some inexpensive, but sturdy mesh (Gorilla wire???) you could probably bend one similar to the Pro Master City Mesh Partition. Here's a picture I found online...not that I'm pushing their product...just for showing how basic it is. Good luck with the search!
Woody
Old 12-06-2021, 06:24 PM   #7
DPowers
One foot in front of the other
DPowers's Avatar
Cargo net thats anchored at four corners?
DPowers is offline   Reply With Quote
Old 12-06-2021, 06:31 PM   #8
CG
BlahBlahBlah
Maybe you can make something like this work?
Old 12-06-2021, 09:45 PM   #9
FLYNAVY30
Yes, the Travel Guard is kind of the direction I was looking to go.
This is what I'm using in my wife's daily driver 4Runner and it works really well...ignore the side pieces (this isn't a pic of our truck). It mounts under the head rests and uses the bolts on the side where the factory hooks go.
Something simple and form fitting like this would be ideal but might not be doable in the Suburban because of the lack of an upper mounting location.
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
Old 12-06-2021, 09:46 PM   #10
FLYNAVY30
I had looked at those as they make them for the 4Runner too.....everyone with Shepherds, Mals, and Labs all said that the creative ones will find their way though the sides over time.
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
Old 12-07-2021, 12:58 PM   #11
HO455
HO455's Avatar
I've seen used ones come up at city auctions occasionally. Ex-police & fire units.
RIP Bob Parks.
Old 12-07-2021, 10:35 PM   #12
BAD1916
Aren’t there provisions for shoulder belts behind the middle seat that you could anchor to? Mine has plugs but I assumed they are threaded?
Old 12-08-2021, 01:48 PM   #13
HO455
HO455's Avatar
It depends on the year. At some point between 67 & 72 GM started installing them. My 67 doesn't have them and I wish I had had the foresight to install them before I installed my headliner.
RIP Bob Parks.
Old 12-08-2021, 03:01 PM   #14
BAD1916
Gotcha. My 71 does. After replying I had to check of those plugs covered threaded holes or not when I got home.
Old 12-08-2021, 09:31 PM   #15
FLYNAVY30
Yes, mine does as well....I'm currently running the 3 point belts both front and rear. I could probably use those to mount the divider as well.
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
Old 12-09-2021, 04:33 PM   #16
CG
BlahBlahBlah
Or if your dog is crate trained you could always put the crate in back and lock it down good. Less chance of fido getting hurt in case of an accident.
Old 12-09-2021, 10:01 PM   #17
FLYNAVY30
Yup, he's crate trained. The problem is I often use the truck for hauling other stuff when I don't have the dog with me and removing and reinstalling the crate is a pain. The crate also rattles something awful while driving.
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
