01-14-2022, 01:17 PM | #1 |
Rear-End Identification help
Can anyone help identify my rear-end?
I posted a reply in a very old thread, but did not have any luck getting responses, so I figured I would try to post a new thread. I have searched the forums and came across a post that referred to some identifying factors, but I'm not sure what it all means. here is the post: http://67-72chevytrucks.com/vboard/s...79#post9018479 Can you help me identify mine? 67890 - GM 12 bolt E120 - May 12, 1970 NF3896838 Axle Stamp = TDA 0521W1 so I think the TDA means its a 3.73 gear and I think the 052 is the 52 day of the year it was built? and I have no clue what the 1W1 means? any ideas? Thanks, Last edited by Tx70Gmc; 01-14-2022 at 03:12 PM. |
01-14-2022, 06:00 PM | #2 |
Re: Rear-End Identification help
Yes, TDA on a 1970 rear end means 3.73 gears. Funny, but on 1971 models TDA means a G30 van with 4.57 gears.
I didn't spend a lot of time searching, but can't find anything on 0521W1.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
01-14-2022, 06:40 PM | #3 |
I did not find the 0521M1 either.
I did find this in the link below. Link: https://www.chevyhardcore.com/tech-s...rearend-guide/
01-14-2022, 06:57 PM | #4 |
I read that entire article and it helped with date code, etc but not the 0521W1
01-14-2022, 07:08 PM | #5 | |
There is lots of info for cars. I tried using different search words to dig a little deeper for truck stuff Maybe someone will know the answer
01-14-2022, 10:19 PM | #6 |
Mike B 71 is a different axle than a 70.
01-14-2022, 10:48 PM | #7 |
I am looking at it a different way. 0521 is May 21st day, W is the plant that assembled the axle, 1 is first shift.
01-15-2022, 12:01 AM | #8 | |
The pumpkin has the code E120, which was May 12,1970 And maybe the axle was made on May 21, 1970? Would that make sense? |
01-15-2022, 05:32 AM | #9 |
01-15-2022, 06:59 AM | #10 |
01-15-2022, 10:58 AM | #11 |
Is the rear axle a five or six lug. What year is your truck? About 95% of the 70 model trucks that I’ve had had the same width housing as 71 and 72. I’m not saying they all do but most that I’ve experienced have.
01-15-2022, 11:02 AM | #12 |
I probably didn’t read all the above post very carefully but here’s a post from a board member years ago as far as the code and gear ratio.
01-15-2022, 11:04 AM | #13 |
Pic
01-15-2022, 01:23 PM | #14 | |
My 69 really looked goofy with its narrow rear end, even with larger 235 tires. Finally went to 255 tires on 8" Rallys which fill the wheel wells perfectly. `
01-16-2022, 08:21 AM | #15 |
5 lug axle length is 31 7/16, 6 lug is 30 3/4.
01-16-2022, 11:43 AM | #16 |
