![]() Join Date: Feb 2004
Inductance adjustment for MIG
I weld, not a professional welder but have been welding for a good while MIG, TIG, and stick. I bought another welder that has an Inductance adjustment for MIG. Did some reading and most (hobby- lower cost) welders have this preset with no adjustment. May be kind of a neat feature to adjust penetration.
Anyone have any experience with this feature? I read also where it enhanced the use of 100% CO2 shielding for migging low carbon steel. My new welder indicates that 100% CO2 can be used with it. Anyone use 100% CO2 at home?
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 02-23-2022 at 04:29 PM. Reason: words |
Re: Inductance adjustment for MIG
Sounds like a neat feature for welding body panels to me.
I have read a few things on it, and I understand it less now. Somehow 🤔 |
![]() Join Date: Mar 2003
I started out about 40 years ago using 100% CO2 and one time tried the 50/50 mix of Ar/CO2........been with it ever since. Now that the prices are getting stupid I may go back. I don't weld anything seriously structural with the MIG. Anything structural I'll step back to Big Red and a box of sticks
#4 | |
At that time I did hvac service so I had practically unlimited C02 access. |
I asked my supplier and he has no customers that use 100% CO2. (out in the country and a small supplier) I will ask him if he can supply me a 20lb for testing sometime. As I understand the inductance adjustment is turned down for just co2.
I tried 100% argon and do not like it for mig steel. They gave me a 100% helium by mistake once and I thot I forgot everything I knew about welding MIG mild steel. I can use the 100% argon for aluminum and stainless TIG. My new welder is a Lift TIG. I have not tried it yet.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 03-07-2022 at 02:39 PM. |
My Hobart has no issues with CO2 vs my other Hobart with standard mig gas. Other then a bit more splatter.
You will need a regulator for CO2, but they are less then a $100. The good news is a typical bottle last almost twice as long and cost about 1/3 as much. |
https://www.weldingtipsandtricks.com...lding-co2.html
I have heard both ways on better and worse on thin panels. Will try -- I think OK for thin also. Z, KW --- I made the leap. I now have a 20 lb tank that measures like propane as the tank has an amount of liquid CO2 in it. For welding it feeds gas to the regulator. As I understand the regulator pressure gauge will read about 700 until the liquid is near gone then it drops kinda suddenly. It is not like argon mix which is all gas in the tank. Weighing it would be a better gauge if you want. A 20 lb size steel Full Co2 tank weighs around 51 lbs and about 31 empty. Aluminum tanks are like 45/25. I got a 320 to 580 adapter to use an argon gauge - $19 on Amazon. Flow settings are about the same. I was welding with .030 on 18 and 20 gauge sheet metal. I usually use .023 - .025 but tried the .030 first. Once you find your setting, welds fine and spatter did not seem much more than the mix. I am still playing with the inductance setting. Correct anything above that is wrong.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 03-07-2022 at 02:47 PM. Reason: pic |
Nice set up , but since you have that 100% Argon bottle , why don't you try out a small roll of silicon bronze wire on that 18-20 gauge, you might be surprised how well it performs and the results you get...
Ok, from what I am reading on it, it appears to be a brazing type process??? I have found 030 but am looking for 023. Can you butt weld with it or does it have to be lap?? thanks
Looks about double cost of carbon steel. https://www.millerwelds.com/resource...brazing-basics
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 04-08-2022 at 05:33 AM. Reason: words |
#10 | |
