Old 12-15-2021, 01:51 AM   #1
Ford Assassin
Ford Assassin's Avatar
Question Anyone Running FRONT Radius Arms?
Decided to go with 10" coilovers from Fox on my 4wd conversion...
Only going with 4 or 6" Lift and no serious off road action....crew cab dually.
I have both 4 link and radius arm options.
Which and why?
Thx
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 12-15-2021, 03:22 AM   #2
Richard
Re: Anyone Running FRONT Radius Arms?
A radius arm axle tends to have a more torsion bar type action as opposed to a four link which will be looser on the articulation movement. The radius arm setup also changes pinion angle and caster quite a bit more through travel over the 4 link. On the 4 link pinion angle and caster remains fairly constant. Was looking at radius arm from Blitzkrieg as well as 4 link by ORD. I chose the four link over the radius arm myself. Am running a sway bar as well which is added cost.
Richard
Old 12-15-2021, 01:08 PM   #3
Ford Assassin
I appreciate the response.
The reason the radius arm setup attracts my attention is the simple nature of it.
Plus I am NOT gonna do any real off roading
Cable
Old 12-15-2021, 01:47 PM   #4
Willowrun
Willowrun's Avatar
I have some Fords with the factory radius arm front suspension and based on how they ride (nice) and the fact you will be using it primarily on the road I would go radius arms all the way. Panhard needs to be parallel with steering arm and caster at 5% or so and you’re good.
Old 12-16-2021, 04:09 AM   #5
Richard
Radius arms will most likely work for you and would have been fine for me. Maybe even without a sway bar. The 4 link was probably more fab work but that is mostly just time for me. I have a higher lift height and wanted to keep link bars or arms flatter. They have to be longer to achieve that. Four link kit allowed for custom length. Flatter bars equal a better ride and road manners. Final deciding factor for me was the radius arm kit I was looking at would have ended up costing more money in the end.
Richard
Old 03-08-2022, 02:08 AM   #6
Ford Assassin
I ended up going radius arms and got the angle at 2* at ride height. 7* of caster. Crossover steering bar and Panhard bar at 1*. If anyone wants to see pics, I can post a few.
Cable
Old 03-08-2022, 10:10 PM   #7
Richard
Lets see some pics
Richard
Old 03-08-2022, 10:18 PM   #8
Ford Assassin
Lets see some pics
Here you go!!
Cable
Old 03-09-2022, 12:22 AM   #9
57taskforce
All about them K’s
57taskforce's Avatar
That’s a hell of a bad ass build! I wish 12 valves hadn’t got so expensive over the last 10 years or so. Really nice work!
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 03-09-2022, 02:49 AM   #10
Richard
Nice! Was that a kit? How is the ride compared to stock?
Richard
Old 04-05-2022, 11:52 PM   #11
Ford Assassin
Sorta. The radius arm kit came from WFO Concepts. The crossover, Panhard bar, and shock towers came from RuffStuff Specialties.
It rides AMAZING. Better than when the truck was still 2wd.
Cable
Old 04-06-2022, 09:19 AM   #12
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice! I've really been considering using some Dodge D60s to take advantage of the coil springs.
Ryan
1969 Chevy milk truck
