04-19-2022, 05:35 PM | #1476 |
Re: Post your 60-66 craigslist finds
No facebook here. Can't see?
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
04-19-2022, 10:23 PM | #1477 |
Condition Used - Fair C10 stepside and c20 propane trucks and a a suburban. Make offer no lowballer
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side. 350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs 20+ year long term project in process Lots of Rust, more memories... |
04-19-2022, 11:01 PM | #1478 |
04-20-2022, 10:19 PM | #1479 | |
cLicky CliCky Quote:
04-20-2022, 10:50 PM | #1480 |
I am fairly certain the 3 speed OD transmission is the same length as the long tailshaft 3 speed transmission, like the one pictured here. I believe the spline count is different, so you need a different slip yoke, but otherwise fits with the current driveshaft.
1961 GMC half ton, short step, Canadian model. Just starting work on it. Last edited by vetnat; 04-20-2022 at 10:53 PM. Reason: clarity |
04-20-2022, 11:02 PM | #1481 | ||
Yes, the 4 bolt side cover overdrive transmissions are the same length as the long tail shaft 3 speeds. I have two of the overdrive transmissions. The one currently in my truck came out of a 65 C10. I forget the count, but it has finer splines on the output shaft than the standard 3 speed I pulled out of my truck. The other overdrive that I have has the same spline count as the old 3 speed I pulled out. I believe the output shaft spline count ran from 55-64 and then changed in 65. Another difference I noticed is that the input shaft necked down on my 55-64 overdrive trans but did not neck down on the 65 I put in the truck.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
04-20-2022, 11:04 PM | #1482 | |
Ive sent him an email, Im in the middle of trying to sort a transmission swap, but $50 is $50, and probably worth the risk
04-21-2022, 12:01 AM | #1483 | |
But yeah, $50 is $50. The overdrive book by Randy Rundle is a great resource for digging into the details on how it all works.
04-21-2022, 07:59 AM | #1484 |
I put one in my 72 because it has 4.56 gears. I love it. Now it has good pickup around town but I can cruise down the highway. I was lucky I did not have to change anything driveshaft wise just the shifter linkage. Mine came out of a 63 Impala. Good Luck!
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) |
04-27-2022, 12:39 AM | #1485 |
1961 GMC half ton, short step, Canadian model. Just starting work on it. Last edited by vetnat; 04-27-2022 at 12:41 AM. Reason: add year |
04-27-2022, 12:42 AM | #1486 |
Pic
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
04-30-2022, 11:14 PM | #1487 |
05-02-2022, 03:08 PM | #1488 |
looks like a N.O.S. ranch hand bumper for a 60-66 . upstate ny area .
https://www.facebook.com/marketplace...3437773312393/
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
05-28-2022, 09:16 AM | #1489 |
Clean 3/4 ton, these don't come around every day. Not mine. Signs of an ex camper hauler, large mirrors and extra tank, which accounts for the much much better than average condition. A set of 19.5's would be in its immediate future if I was in the market. https://sacramento.craigslist.org/ct...485754110.html
05-28-2022, 09:44 AM | #1490 |
But Found Her 25yrs Later!
And in a nice dry area of California.
Sadly though, who ever buys it will probably convert it to a half ton, put an LS in it and lower it - ruining the 'grandpa truck' beauty of it.
05-28-2022, 10:27 AM | #1491 |
Right, the grandpa looking truck becomes an ex-grandpa looking truck, seen it many times. Large percentage of the original buyers of these 3/4 ton camper boom type trucks were veterans from WWII and Korea, they wanted travel, explore and enjoy the large beautiful country they fought for and put there lives on the line for.
05-28-2022, 11:13 AM | #1492 |
You guys are a couple of decades off. Those are now great grandpa trucks
05-28-2022, 09:51 PM | #1493 |
64 GMC Motorhome $6K
She's a beaut Clark! |
05-30-2022, 07:50 AM | #1494 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-30-2022, 12:21 PM | #1495 |
Read the GMC camper ad ( very clean original piece by the way Jocko), looks like somebody already destroyed the clutch. Note position of pedal. Never liked the way the 4 speed gear shift pattern was for rookie drivers, some latter patterns had the more accurate L 1 2 3, I could see how somebody could blow a clutch or U joint pronto.
05-30-2022, 04:12 PM | #1496 |
I think it was ruined at the manufacturer when they put the camper on it
05-30-2022, 04:29 PM | #1497 | |
I'll take two hot dogs and three beers please! LOL! |
06-09-2022, 10:30 AM | #1498 |
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
06-22-2022, 01:38 PM | #1499 |
MusicMan70 1961 GMC Suburban |
07-21-2022, 09:44 AM | #1500 |
Found this 61’ for $12. Going to look at her tomorrow. What do you guys think. I feel it’s worth way more then that in its current state. Minor Surface rust above window and on bottom of doors he says. 350 with a Muncie 4 speed with Bluetooth radio 🤙🏻
