![]() Join Date: Aug 2010
WTB: 1980-87 Steering Center Link
Have a 80s something drag link or center link on my 65, PO did a power steering swap and now I have the 80-something steering parts. . Is bowed a bit in the middle, could beat on it to straighten, but would rather find a NOS or less worn one ...
Can't find a new one to buy, apparently considered "not a wear item" ?? Thx! Roy
1965 Suburban Waiting on Time and Money |
#2 | |
Re: WTB: 1980-87 Steering Center Link
![]() ![]() ![]() Join Date: Jan 2018
I think it might be the same from 73-87, but not 100% certain on that one.
My guess is it's not considered a wear part because all the wear parts bolt to it
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#4 | |
was checking the idler arm location after putting in CaptainFab's PS bracket and noticed the center link was bowed a bit, kinda matching the curve of the crossmember. I assume it's supposed to be perfectly straight...
If you receive a pm from Rckjonas (account suspended), be aware… it seems fishy… tells you his buddy Jamie has the part you need. You email Jamie and arrange for shipping and payment via PayPal or whatever. Gives you a different PayPal email. Khairdahur@gmail.com
I didn’t send $… doesn’t smell right. Anyone else gotten pm from him?
That's why that account was suspended. Apparently, the user sent multiple PMs saying to email someone else. When did you first receive the PM from that user?
Also, good on you for sniffing it out and not sending your money to that scammer. Some scammers have started using tactics to get around the usual scam/spam filter stuff that the site has. Liz gives them the boot as soon as they are discovered
#7 | |
#8 | |
I looked and that user sent three separate PMs on the 14th regarding "parts" that someone else had and to email that "person". Said user was promptly banned by Liz as soon as the first PM was reported on the 14th. Again, thank you for being cautious and letting us know about the issue
#9 | |
#10 | |
#11 | |
Still looking...
![]() Join Date: Nov 2018
Are you a 1/2 or 3/4 ton?
#15 |
![]() Join Date: Nov 2012
I had trouble too. Found one in a U-Pull yard close by. See this post-
http://67-72chevytrucks.com/vboard/s...d.php?t=831522 For interchangeability: '73-'82 C10/20/30 are the same- GM p/n 6270303 - Rod, steering connector '83-'86 C10/20/30 & '87-'91 R10/20/30 are the same- GM p/n 14067697 - Rod, steering connector Not sure what the difference is between these 2 p/ns Last edited by VictoriaHardware; 02-11-2023 at 01:39 PM. Reason: added info |
#16 | |
#17 |
Found one, Thanks Sheepdip!
#18 |
Glad it worked for you!
