Old 04-28-2022, 01:11 PM   #1
Southcity
Southcity's Avatar
Wheel and Tire help - 66 4x4 Suburban
Long time board member with very little 4x4 wheel/tire knowledge, please bare with me. Hoping the 4x4 guru's can provide some guidance/recommendations based on the below:
1.Want to run radial over bias ply
2.Want the tall/skinny offroad look (keep wheel/tire inside fender wells)
3.Vehicle is 66 4x4 Suburban (stock height, no lift)
4.Wheels will be new OE style GM truck steelies. Either 15x6 or 15x7 so I can run dogdish caps.
Want the tallest/skinniest radial 4x4 tire I can safely run and try keep that "close to stock" look. Thanks in advance.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 04-28-2022, 01:54 PM   #2
Short 3/4
Re: Wheel and Tire help - 66 4x4 Suburban
Assuming 1/2 ton?
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 04-28-2022, 02:04 PM   #3
Southcity
Southcity's Avatar
Fair question Short 3/4. Vehicle is 66 4x4 Suburban (6 lug) which as I understand it makes it a 1/2 ton. Apologies, I don't yet own the vehicle so am unable to validate.
Old 04-28-2022, 02:26 PM   #4
mongocanfly
mongocanfly's Avatar
not sure how bigga tire you can run , but thisll help you with what is what for tire sizes
https://tiresize.com/chart/
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-29-2022, 02:21 AM   #5
b454rat
I had 35s on my 62. Weren’t tall n skinny but fit just fine. A 255/85/16 is a skinny tire, smidge over 33” I think.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 04-29-2022, 07:17 AM   #6
mongocanfly
("A 255/85/16 is a skinny tire, smidge over 33” I think.")
b454rat..they are... i have 2 sets of those
but hes wanting 15s
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-29-2022, 09:11 AM   #7
cadillac_al
BFG used to make a 235/85r15, probably not anymore. If I had lots of money I would get custom 16" wheels made for the 6 bolt pattern and run the 235/85r16 tire. They may already make those wheels but not cheap.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 04-29-2022, 11:58 AM   #8
Southcity
Southcity's Avatar
Appreciate the responses all, thanks. I am taking a slightly different approach and am going to go with a 16x6 wheel rather than 15". It will be a few weeks before I have the vehicle and a few more to obtain the new wheel/tire combo. I will do my best to update with pics here once I get there.
Old 04-29-2022, 12:10 PM   #9
mongocanfly
it may be hard to find a taller tire for the 6in wide rim...i wanted the tall/skinny , so i went with 255/85-16s..but i had to step up to a 8in wide rim to run them
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-29-2022, 12:44 PM   #10
Southcity
Southcity's Avatar
Originally Posted by mongocanfly View Post
it may be hard to find a taller tire for the 6in wide rim...i wanted the tall/skinny , so i went with 255/85-16s..but i had to step up to a 8in wide rim to do run them
Thanks mongocanfly and understood. I am not set on tire size or wheel width yet but do know I am going to go with a 16" wheel. Any chance you can post a pic or two of the wheel/tire setup you mentioned above?
Old 04-29-2022, 01:02 PM   #11
Short 3/4
I have always used a 235/85 16 radial and I think it’s a nice stock look on these era trucks, and still fairly easy to drive with manual steering. Have mainly used 70-80’s steel take off rims, but mine always 8 lug, so easier to find.
BTW I just learned that all Suburbans are 1/2 ton, so my first post was kind of redundant.
Have fun with the new project
Tom
292-SM420-T221
Old 04-29-2022, 01:31 PM   #12
mongocanfly
this is the set with black rims...i have the other set mounted on white rims, ill add a pic of those tonite
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-29-2022, 01:37 PM   #13
Southcity
Southcity's Avatar
Thanks for the pic, that does look good! To confirm the wheel/tire sizes in that pic?
wheel = 16x8
Tire=255/85R16
Old 04-29-2022, 02:11 PM   #14
mongocanfly
yep...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-01-2022, 07:31 PM   #15
Stocker
20' Daredevil (Ret)
Stocker's Avatar
For the record, 255/85-16s fit perfectly on 7" wide wheels too. That's what I have (on Ford wheels) on my K20.
Tire Rack shows a recommended rim width of 6.5"-8", and a measured rim width of 7".
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 05-01-2022, 07:43 PM   #16
mongocanfly
I looked for a set of those Ford rims, but never found any
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-01-2022, 07:49 PM   #17
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I got lucky, found mine in a junkyard about 6 years ago.
- Mike -
RIP El Jay
Old 05-01-2022, 09:50 PM   #18
mongocanfly
Wernt those rims just on Ford vans?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-02-2022, 11:36 AM   #19
Southcity
Southcity's Avatar
[QUOTE=Stocker;9073908]For the record, 255/85-16s fit perfectly on 7" wide wheels too. That's what I have (on Ford wheels) on my K20.
Appreciate the info and pics, Stocker. That is one nice truck and a sweet wheel/tire setup.
Old 05-02-2022, 08:34 PM   #20
Stocker
20' Daredevil (Ret)
Stocker's Avatar
No sir, they were on F250s up until 1996. Ford changed them to a metric bolt pattern in 1997. Van wheels didn't change until later, but I'm not sure which year.
Thanks! It should be out of paint prison soon and I'll post up some fresher pics.
- Mike -
RIP El Jay
Old 05-03-2022, 04:08 PM   #21
mongocanfly
Heres a pic of the set I have mounted on white...really like the way these look
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-03-2022, 05:08 PM   #22
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Those look great!!
- Mike -
RIP El Jay
Old 09-15-2022, 01:47 PM   #23
Southcity
Southcity's Avatar
As promised and thanks to all the board members that chimed in with helpful info. 16x6 smoothies arrived 4 1/2 months after ordering, currently at the powder coater. Next post will be before/after shots.
Old 09-29-2022, 06:11 PM   #24
Southcity
Southcity's Avatar
Before/After shots
Wheels = 16x6 smoothies, powder coated
Tires = 255/85R16 BFG KM3
BEFORE:
AFTER:
