![]() Join Date: Aug 2007
Side Glass Removal Question
I plan to have my single wall top raptor lined but I need to change the side glass. I found some info here to get seal warm and plastic tools to pry out, this is original near as I can tell it's not very flexible. Do they reproduce single-wall window seals?
Thanks 7D2N
Just for the fun of it |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Side Glass Removal Question
Single wall glass seals are available. SoffSeal product maybe? Classic Heartbeat and GMC Pauls both carry these.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Thanks, I will check into them.
2WD Jimmy
![]() Join Date: Mar 2005
Take a sharp knife to your old rubber. Cut off one side and push out the glass.
Thanks Tom, I will probably have to cut the old rubber seals not to damage my glass.
2WD Jimmy
![]() Join Date: Jan 2001
A little glass cleaner on the rubber will make your utility knife slice through it much more easily.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Check as you push. I have seen a number where adhesive was used and it gets on the top itself. Easy to break a window when pushing. But yep, the utility knife rips right thru most of the time.
Made me think of a funny story.....I had a top once that was way beyond any repair. Just not a lot to work with but it had two really nice side windows, Sun ray at that. A guy wanted to buy them but they had been glued in the rubber and the rubber had been glues to the top. He offered way more that what I thought they were worth but back tracked when they would not come out. He said at home he could use a heat gun and get them out. I told him to stand back and I uses a circular/skill saw and cut his two windows out giving him a bit of top as well. The next day he posted he had met the "Marcel Leddbetter" of Blazer parts. Not suggested as a means to remove your windows. Scott |
