Leaf springs replace vs rebuild.
My truck always had a 1" lean to the passenger side. To which I assumed to be the fact the stepside was missing its wood, and something fell down on the frame. It was level last August when I started driving the truck.
Well as I am beginning work on the suspension. I found out my spring has sagged. So I have 2 choices rebuild or replace. Anyone rebuilt sagged springs for them to sag quickly again? |
![]() Join Date: Mar 2003
Re: Leaf springs replace vs rebuild.
A good spring shop will make them just like new or better. I have older springs rebuilt all the time
Thanks.
I got lucky my cousin still has Suburban springs I can have. So I will just have to remove some springs to adjust the best I can |
#4 | |
Look for cracks and rust, those are the bad part, most of the time.
Up here in the rust-belt, they will get so crusty as to swell around the U-bolts. Then the leaves spread open and it just gets worse. If you separate a pack like that, they generally just fall apart. No rebuilding those, because they will be pitted and thinner than they should be. If they look good and are just sagging, a rebuild can save them.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
driving is in my blood
How does one rebuild a metal plate?
I get re-arching them, but what else is there to do?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
