Old 07-18-2022, 10:39 PM   #1
pontiacvince
pontiacvince's Avatar
700r4 Linkage
What linkage do I use from the frame to the trans on a 700r4?
'67 - '72.
pontiacvince is offline   Reply With Quote
Old 07-18-2022, 11:27 PM   #2
Accelo
Accelo's Avatar
Re: 700r4 Linkage
If the header/exhaust isn't in the way I prefer the stock style linkage. One only has to relocate the frame side. I have made several work perfectly and only had to relocate one hole, by drilling the frame, and just pivoted on the other.
Works slick.
With headers or exhaust in the way it's a different story. Then the aftermarket linkage works the best.
Cheers
Accelo is offline   Reply With Quote
Old 07-18-2022, 11:42 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Re: 700r4 Linkage
I’ve used Kugel Komponents aftermarket linkage for a factory column shift. It’s the same design as Lokar but less $$. It’s designed after factory linkage but is adjustable, which is nice if you have an overdrive trans and swap out the shift indicator lens to reflect the overdrive.
https://www.performanceonline.com/Au...UaAn6YEALw_wcB
This is one vendor but you can probably find it even less.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 07-19-2022, 12:07 AM   #4
pontiacvince
Re: 700r4 Linkage
Thanks, guys!
