09-07-2022, 10:35 PM | #1 |
Breaking Tailgate handle screws loose?
I have my Tailgate off so I could repair some rust holes, and figured I could take the Latch Handle off, to clean it up and prep for painting later.
It appears that the mounting screws have never been loosened since the truck left the Factory in 1970. My question is this: Is there an easy/safe way to get the Three mounting screws loose without stripping them out? As I was leaving the shop, I sprayed them with penetrating oil, and tapped on them to help with the process. In the morning, I’ll spray the other side the best I can to hopefully get the threads penetrated. I’ve been fortunate (so far) with any disassembly I’ve done, in that the bolts are coming loose without me breaking off any of them. I hope my streak continues |
09-07-2022, 10:58 PM | #2 |
Location: Herculaneum MO (20 minutes south of St. Louis
Re: Breaking Tailgate handle screws loose?
Impact driver. Something like this. Also make sure you have the correct bit. It looks like it's a #4 Phillips which is a larger bit than a lot of people have.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris Last edited by 67 twins; 09-08-2022 at 12:18 AM. |
09-07-2022, 11:38 PM | #3 |
Heat them up. I use a propane torch, just have to hold it there a long time.
09-08-2022, 08:46 PM | #4 |
I like the impact driver and heat ideas. Believe it or not, if they don’t break loose trying to back them out, I’ve tried tightening them with a few wacks and them go back to loosening
71 C10 72 K20 72 K10 Super Kirk |
09-08-2022, 08:56 PM | #5 |
09-08-2022, 09:00 PM | #6 | |
Tomorrow I’ll play with it a little more. When I go to town Saturday, I plan on getting an Impact Driver, so one way or another they’ll come out BTW the thread ends look to be in good shape and not too rusted. |
09-09-2022, 05:50 PM | #7 |
Update:
Today, on a whim, I tried to turn the screws, just to see I they would Hallelujah! All three loosened with very little effort!!!. Tomorrow I finish up with the welding on my Tailgate, then move right to the Rocker Panel repairs |
09-10-2022, 02:09 PM | #8 |
Good deal!!
09-10-2022, 03:23 PM | #9 |
Glad you got them loose.
I am late to the party for suggestions I have had good luck with regulator and tailgate screws by using a Milwaukee impact driver. Link: https://www.northerntool.com/shop/to...9790_200709790
09-11-2022, 09:01 AM | #10 | |
Yes sir! The next time I go to town (im in the country, 25 miles out. )I’m coming home with one. On a side note: Sea Foam “DEEP CREEP” is awesome stuff. Last edited by custom10nut; 09-11-2022 at 09:03 AM. Reason: Add to message |
