Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 08-14-2022, 07:47 AM   #1
scott123
S-10 interchangeable parts
I have access to a 98-99 Chevrolet Blazer. Will the front suspension bolt to a 95 frame?
Will the Blazer rear go in the 95 S-10? Bolt up, or will I have to move perches?
Setting things in motion for a frame swap.
Never pulled down/put together many S-10's.
Scott
scott123 is offline   Reply With Quote
Old 08-14-2022, 08:05 AM   #2
scott123
Re: S-10 interchangeable parts
Both are 4WD. Forgot the most important part.
Scott
Old 09-09-2022, 08:14 AM   #3
OL SKOOL
OL SKOOL's Avatar
The front suspension should bolt in ok. I did yours backwards. I had a 96 blazer and put control arms on my 2000 s10 front end. The Blazer rear end i believe is wider than the pickup drum to drum.
OL SKOOL is offline   Reply With Quote
Old 09-11-2022, 02:46 PM   #4
Just call me Sean
Just call me Sean's Avatar
4wd rear is four inches wider than 2wd, truck or Blazer.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
