Old 10-11-2022, 09:29 PM   #1
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Turn/wiper/dimmer switch issue
I just put a new turn signal cam switch and ignition key switch in my 86 M1009 Blazer. The turn switch will not allow me to give a left signal because the rod hits the column housing when I attempt to do so. For some reason the wiper/dimmer switch seems bad or worn out somehow. I cannot seem to figure out exactly how this is removed and replaced.Can someone help me with this?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 10-13-2022, 10:57 AM   #2
kwmech
Re: Turn/wiper/dimmer switch issue
The dimmer switch is further down the column and is actuated by a rod making its way up to the turn switch. sounds like when you put it back together you missed the alignment of the 2 at the top. there is a piece that forms itself into the turn switch kinda shaped like a tear drop.
Old 10-23-2022, 09:12 PM   #3
HIGHWAY BY THE SEA
Thanks for the reply! I was able to figure it out and install everything perfectly.
