Old 11-02-2022, 04:36 PM   #1
Johnl48
Question about wiring
I'm in the process of wiring on my restoration 70 c20
I'm using the factory harness
Positive cable to starter
Purple wire from harness to starter
Wire from positive terminal to junction block on pass fender which I assume powers the fuse block ?
My issue is I'm getting power to just a few fuses, no switched power and nothing to starter with key
Is rhere some other source to power ignition switch?
Old 11-02-2022, 04:56 PM   #2
kwmech
Re: Question about wiring
Should have a 12v feed to the ign switch and a working ign switch to feed the fuse block
Old 11-02-2022, 05:06 PM   #3
Johnl48
Where does the 12v feed come from that one block on the fender ?
Old 11-02-2022, 05:36 PM   #4
pjmoreland
pjmoreland's Avatar
That is correct. Here's a link to some schematics that show the red wire running from the fender junction block to the fuse panel and ignition switch.
http://67-72chevytrucks.com/vboard/s...d.php?t=185856
pjmoreland is offline   Reply With Quote
Old 11-02-2022, 10:16 PM   #5
franken
BTW there should be a fusible link between the battery and the junction block...
franken is online now   Reply With Quote
Old 11-03-2022, 06:56 AM   #6
Johnl48
What size fuse should go there ?
Old 11-03-2022, 07:19 AM   #7
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
A fusible link is a short section of sacrificial wire spliced into the various power feeds for accessories. They are usually 4 wire gauges smaller that the power wire they are designed to protect. Here's a good explanation, https://www.youtube.com/watch?v=Tg7K343N5w0&t=138s
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 11-03-2022, 07:25 AM   #8
Johnl48
Just wondering if I can put an inline fuse in ? Easier to change if blown
Old 11-03-2022, 07:45 AM   #9
dmjlambert
dmjlambert's Avatar
It should never blow, it only does if there is a really bad short. Normally it should last for decades. Our trucks normally have 12 guage wire as the largest unfused wiring in the truck, so to protect that you would use a piece of 16 gauge fusible link wire about 6 to 9 inches long to connect the battery to the junction block. It has a special non-flammable insulation and they are usually grey. Pieces of fusible link wire are sold in car parts stores, usually in a blister pack.
Old 11-03-2022, 07:50 AM   #10
Johnl48
Thank you
Old 11-03-2022, 09:03 AM   #11
Grumpy old man
Grumpy old man's Avatar
This should help .
http://www.madelectrical.com/catalog/fusible-link.shtml
Old 11-03-2022, 09:11 AM   #12
Johnl48
So I'm getting power to everything except the purple wire to the starter via ignition switch. This is an automatic converted from a 4 speed. Was there a NSS with the 4 speed from factory I'm missing ? I don't see any plugs under dash for one
Old 11-03-2022, 09:43 AM   #13
Johnl48
I figured the starter issue out. Battery problem. Thanks
