Old 03-09-2023, 10:36 AM   #1
KyleSeal
KyleSeal's Avatar
1967 (maybe 68?) Steering Column Assembly...
I recently decided to rebuild my 67's column (automatic) and have found very little info on these 67 (possibly 68 as well) columns, as they are a bit different.
The lower section seems to be the most different, so here are some pics for future reference, for anyone who runs into an issue figuring out how it stacks up:
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 03-09-2023, 10:38 AM   #2
KyleSeal
KyleSeal's Avatar
Re: 1967 (maybe 68?) Steering Column Assembly...
Here's some of the assembled look... the 3/4 'band' clamp/brackets hold the lower bearing retainer and the shift arm assembly, I offset them just because that seemed to make sense to me. I gave everything a skim of wheel bearing grease before assembly, to keep them from drying up or corroding.
Old 03-09-2023, 10:55 AM   #3
sambrutay
sambrutay's Avatar
Very nice. I will probably be doing this soon on my 67. Thanks for the info.
Bruce
1964 C10 SWB #Junk
1979 C10 utility #cargopants (sold)
1971 GMC Sprint (sold)
1974 GMC Grande Sierra (sold)
sambrutay is offline   Reply With Quote
Old 03-09-2023, 12:50 PM   #4
pjmoreland
pjmoreland's Avatar
The steel washer and white plastic bushing are not supposed to be installed there. There should be a gap in that location instead to allow the shift rod arm to disengage from the detent plate when you pull the shift lever toward you.
The steel washer and white plastic bushing belong up at the top end of the column, below the piece that the shift lever attaches to.
pjmoreland is offline   Reply With Quote
Old 03-09-2023, 01:03 PM   #5
CKfan
100% agree
CKfan is offline   Reply With Quote
Old 03-09-2023, 02:39 PM   #6
KyleSeal
KyleSeal's Avatar
Interesting - I will correct tonight. Thank you for the clarification!
Mods - if you can delete my original photos, I will correct and repost.
Old 03-09-2023, 04:37 PM   #7
KyleSeal
KyleSeal's Avatar
These are the updated photos - thank you guys for the correction!
Old 03-09-2023, 05:10 PM   #8
pjmoreland
pjmoreland's Avatar
Looks good!
Old 03-09-2023, 06:46 PM   #9
HO455
HO455's Avatar
That's really nice. Where did you find such a low mileage column? The shifter detents look brand new.
RIP Bob Parks.
1967, automatic, column, rebuild
