04-09-2023, 11:04 AM | #1 |
Junior Member
Ac vent kit
Hello, Happy Easter.
I have a 71 C10 without factory air. It is getting close to being ready for paint and I am looking for advice on a Kit just for the 3 dash vents for now. I'm looking for a kit that will look close to OE but be easy to install, ie: dash cutting. I figure I will add the complete system later on, but for now just want to do the dash mods before paint. Any ideas on which company to go to for the parts ? or a Kit that has templates? I did try and search, but I didn't have much luck? Thank you, Dan |
04-12-2023, 10:27 PM | #2 |
Re: Ac vent kit
Moved to the 67-72 message board for ya. Should be able to get an answer here
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
04-13-2023, 03:22 AM | #3 |
Re: Ac vent kit
I opted to cut my dash for the OEM dash vents and will install a stock type system. There are pics in the earlier posts of my build thread. Converting to r134a as opposed to an aftermarket system. IIRC some of the aftermarket venders offer adapter to convert their smaller ducts to the larger stock vents if you choose that path. Unfortunately, the person I got the templates from is no longer on this forum. PM me if you want more info on what I did.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-13-2023, 09:19 AM | #4 | |
Junior Member
Re: Ac vent kit
04-13-2023, 09:25 AM | #5 |
Re: Ac vent kit
If you are going with Vintage Air, their website has downloadable instructions and you can use their templates. Just verify the paper prints in the proper dimensions when doing so.
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
04-13-2023, 09:37 AM | #6 |
Re: Ac vent kit
I found a used set on the parts board and used them as patterns to cut the Factory style vent holes in my 67 dash , The vents that come with the vintage air kits are just a generic looking round vent .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
04-13-2023, 09:39 AM | #7 |
Junior Member
Re: Ac vent kit
04-13-2023, 09:47 AM | #8 |
Junior Member
Re: Ac vent kit
04-13-2023, 10:08 AM | #9 |
Junior Member
Re: Ac vent kit
I see Old Air Products sells a factory look 3 piece kit for the dash vents. I would think these need to holes and center cut out to be to factory spec's ? I just can't find the Templates so I can print them out in real size ? I am terrible searching the web. Maybe someone has what I need ? Willing to pay for them . I just want to cut everything out correctly. Thank you
04-13-2023, 10:31 AM | #10 | |
Junior Member
Re: Ac vent kit
Thanks for everyone's replies. |
