#26 |
Re: CPP disc brake conversion brake line routing
Grumpy...I'm hoping you or someone elese has a little more insight for me. Inline Tube's video is fantastic for the install, thanks again. It has links with model numbers and everything. I called Inline and unfortunately they do not sell this in a kit for our trucks, when I bought seperatly, they do not have a master cylinder currently...so I'm trying to pick one up from Summit. I found a CPP (CLP-MC118-L) but it says it's a 1.125" Bore, and the guy from Inline said the trucks need a 1" bore. Can anyone confirm which MC I need?
#27 |
#28 |
![]() Join Date: Dec 2013
6772BB24
1967-72 OEM Style Brake Booster Kit, disc/drum, kit. 2 disc of 4 disc. Photo/Info $389.00 https://www.classicperform.com/Store...ck/6772BBD.htm https://www.inlinetube.com/products/brk03a I would call CPP and double check it's what you need and if they carry the bracket to mount the prop valve under rhe master . Inline used to sell it and with the prop valve mounted under the master it fits inlines Stainless line kit . ![]()
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#29 |
![]() Join Date: Nov 2013
Not sure what your budget is, but I bought this kit from a board member here...damn nice and it locks all 4 wheels on my Blazer....complete kit
https://67-72chevytrucks.com/vboard/...hlight=booster
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
#30 |
CPP helped me out. Once all parts get in...we'll see how it all goes together. I'm going to try and run most of the lines this weekend. We'll see, we just finished rebuilding the rearend and are going to get that put back in it this weekend too. Thanks for the advise guys.
#31 | |
Anyways, looks good man. Thanks for the pic. |
#32 | |
#33 |
![]() Join Date: Jun 2022
here's the MBM links for both mounts. I find their instructions to be pretty good(might help make sense of other brands' kits)
https://mbmbrakes.com/gm-left-side-p...-drum-brass-1/ https://mbmbrakes.com/gm-bottom-moun...-drum-brass-1/ https://mbmbrakes.com/master-cylinde...ioning-valves/ https://mbmbrakes.com/instruction-manuals/ |
